The Philips ergonomic LED display using 25% recycled materials and PVC-BFR free housing is ideal for eco-friendly productivity.
Product Description | Philips S-line 220S4LYCB - LED monitor - 22" | Device Type | LED-backlit LCD monitor - 22" | Aspect Ratio | 16:10 | Native Resolution | 1680 x 1050 at 60 Hz | Pixel Pitch | 0.282 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 20000000:1 (dynamic) | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Textured black | Dimensions (WxDxH) - with stand | 50.4 cm x 22.7 cm x 50.9 cm | Weight | 5.2 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, FCC Class B certified, UL, TUV, TUV GS, BSMI, cUL, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, CECP, CU-EAC |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Vertical Refresh Rate | 56 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | WLED |
OSD Languages | Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean |
Features | Sync on Green, sRGB colour management, SmartContrast, SmartImage, TrueVision, SmartPower, Smart Ergo base, BFR/PVC-free, Mercury free |
Dimensions (WxDxH) | 50.4 cm x 22.7 cm x 50.9 cm - with stand |
Weight | 5.2 kg |
Connectivity | |
Interfaces | VGA , DVI-D (HDCP) , DisplayPort , Audio line-out |
Mechanical | |
Tilt Angle | -5/+20 |
Swivel Angle | 130 |
Rotation Angle | 90 |
Height Adjustment | 110 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
MTBF | 70,000 hour(s) |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
OS Required | Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 50.4 cm - depth: 22.7 cm - height: 50.9 cm - weight: 5.2 kg , Without stand - width: 50.4 cm - depth: 5.9 cm - height: 34.9 cm - weight: 3.38 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
