Turn on your peace of mind
Include a Philips Hue White bulb in your Philips Hue system and experience high-quality white light that you can dim smoothly. Connect it to the Philips Hue Bridge and control it with your smartphone or tablet.
Easy, reliable and future-proof system
Away-from-home control
You can control your lights remotely wherever you are. Check if you have forgotten to switch your lights off before you left your home, and switch them on if you are working late. With geofencing technology, your lights can even welcome you home or switch off automatically when you leave your home. It's all
about simplifying your life and giving you peace of mind in smart and useful ways.
Comfort dimming
Experience guaranteed smooth dimming with Philips Hue. Not too bright. Not too dark. Just right. No need for wires, an electrician or installation.
Set light schedules
Philips Hue can make it seem like you're at home when you're not, using the schedule function in the Philips Hue app. Set the lights to come on at a pre-set time, so the lights are on when you arrive home. You can even set rooms to light up at different times. And of course, you can let the lights turn off gradually in the night, so you never have to worry whether you've left any lights on.
Smart control
Connect your Philips Hue lights with the Bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app, or add switches to your system to activate your lights. Set timers, notifications, alarms and more for the full Philips Hue experience.
Expand your ecosystem
You can connect up to 50 lights and 10 accessories to the Philips Hue Bridge (included). Simply begin with any of the available starter kits and start adding Philips Hue products. You can then control your lights at the swipe of a finger with the intuitive Philips Hue app for iOS and Android smart devices. Philips
Hue is based on ZigBee, a low-power, safe and reliable technology to control your lights. New features and improvements are continuously added to the system. Updates to both software and firmware are made wirelessly and seamlessly directly to your Philips Hue product.
Product Description | Philips Hue White - LED light bulb |
Light Bulb | |
Type | LED light bulb |
