Outstanding audio quality with Philips transcription headphones
The lightweight under-the-chin style headphones with dual sound system are designed to deliver excellent sound quality, with soft ear cushions for wearing comfort, and a hanging bracket that attaches the headset to a monitor.
Superior audio quality
For optimal results
A 14 mm speaker driver optimizes high audio quality
Small enough for optimum wearing comfort, yet large enough to deliver crisp, non-distorted sound, the 14 mm speaker driver is the ideal size to deliver high quality sound.
Gold-plated plug ensures an ultra-reliable connection
The precious-metal gold finishing on the plug will produce a more reliable connection for better audio quality.
Neodymium magnet enhances sensitivity and sound quality
Neodymium is the best material for producing a strong magnetic field for greater sensitivity and higher overall sound quality.
Lightweight design improves comfort for prolonged use
The durable, lightweight quality materials enhance comfort for extended wearing.
Under chin style to fit all ears for better comfort
Designed for an under-the-chin fit for better comfort.
3 meter/10-foot cable for freedom to move about your work area
The 3 meter/10-foot cable gives you the freedom to move around your work area without having to remove the headphones.
Product Description | Philips LFH0334 - headphones | Product Type | Headphones - wired - 3.5 mm jack | Headphones Form Factor | Under-chin | Connectivity Technology | Wired | Headphones Technology | Dynamic | Sound Output Mode | Stereo | Audio Specifications | Sensitivity 103 dB | Diaphragm Type | PET |
General | |
Audio Output | |
Sensitivity | 103 dB |
Diaphragm | PET - 14 mm |
Magnet Material | Neodymium |
Connections | |
Connector Type | Headphones (mini-phone stereo 3.5 mm) |
Cable | |
Plated Connector | Gold |
Miscellaneous | |
Cable Details | Headphones cable - 3 m |
