Colours like you've never seen before. This brilliant wide-view Quad HD display with Ultra Wide-Color offers crisp images with the richest and most vivid colours on an elegant display for your best creations yet.
Product Description | Philips E-line 276E8FJAB - LED monitor - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class C | Energy Consumption per Year | 70 kWh | Power Consumption (On mode) | 46 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | QHD 2560 x 1440 at 60 Hz | Pixel Pitch | 0.233 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 / 20000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 114% NTSC, 132% sRGB | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black, gun metal | Dimensions (WxDxH) - with stand | 61.3 cm x 18.9 cm x 46.6 cm | Weight | 4.69 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, FCC Class B certified, DDC/CI, RoHS, Lead-Free, WEEE, CECP, EPA, RCM, CU |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Panel Type | IPS |
Pixel Per Inch | 109 |
Vertical Refresh Rate | 46 - 75 Hz |
Horizontal Refresh Rate | 54 - 84 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
OSD Languages | Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean |
Features | Sync on Green, SmartImage Lite, SmartContrast, Flicker Free technology |
Dimensions (WxDxH) | 61.3 cm x 18.9 cm x 46.6 cm - with stand |
Weight | 4.69 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 3 Watt |
Connectivity | |
Interfaces | HDMI (HDCP) , DisplayPort , VGA , Audio line-in , Headphones |
Mechanical | |
Tilt Angle | -5/+20 |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x HDMI cable , 1 x audio cable |
MTBF | 50,000 hour(s) |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 22.93 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
OS Required | Apple MacOS X, Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.3 cm - depth: 18.9 cm - height: 46.6 cm - weight: 4.69 kg , Without stand - width: 61.3 cm - depth: 4.1 cm - height: 37.4 cm - weight: 4.07 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
