The Philips PowerSensor display using post-consumer recycled plastics and PVC, BFR-free housing is ideal for eco-friendly productivity.
Product Description | Philips Brilliance B-line 240B7QPTEB - LED monitor - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class E | Energy Consumption per Year | 38 kWh | Power Consumption (On mode) | 18.9 W | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:10 | Native Resolution | 1920 x 1200 at 60 Hz | Pixel Pitch | 0.27 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 20000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA, DisplayPort, Mini DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Textured black | Dimensions (WxDxH) - with stand | 53.3 cm x 25.7 cm x 54.9 cm | Weight | 6.57 kg | Environmental Standards | TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified | Compliant Standards | Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, EPA, cETLus, CU-EAC |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Viewable Size | 24.1" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Vertical Refresh Rate | 56 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
OSD Languages | Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean |
Features | sRGB colour management, PowerSensor, SmartResponse, SmartImage, edge-to-edge glass, Smart Ergo base, SmartConnect, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Ultra Narrow Border, Mercury free, USB 3.0 Fast Charge, Wide Viewing Angle, Sync-N-Go |
Dimensions (WxDxH) | 53.3 cm x 25.7 cm x 54.9 cm - with stand |
Weight | 6.57 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , DisplayPort , Headphones , Audio line-in , 4 x USB 3.0 , HDMI , DisplayPort output , Mini DisplayPort |
Mechanical | |
Tilt Angle | -5/+30 |
Swivel Angle | 350 |
Rotation Angle | 90 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x DisplayPort cable , 1 x audio cable |
MTBF | 70,000 hour(s) |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 18.9 kWh/1000h |
Power Consumption (Typical) | 15.2 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0 Watt |
On / Off Switch | Yes |
Software / System Requirements | |
Included Software | Philips SmartControl |
OS Required | Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 53.3 cm - depth: 25.7 cm - height: 54.9 cm - weight: 6.57 kg , Without stand - width: 53.3 cm - depth: 5.7 cm - height: 36 cm - weight: 4.14 kg |
Sustainability Information | |
TCO Certified | TCO Certified Displays 8, TCO Certified Edge Displays |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
