The Philips ergonomic AH-IPS LED display using 25% recycled materials and PVC, BFRfree housing is ideal for eco-friendly productivity.
Product Description | Philips S-line 221S6QYMB - LED monitor - Full HD (1080p) - 22" | Device Type | LED-backlit LCD monitor - 22" | Power Consumption (On mode) | 16.96 W | Panel Type | AH-IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.248 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 20000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey), 14 ms (typical) | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Textured black with black stand | Dimensions (WxDxH) - with stand | 51.1 cm x 22.7 cm x 48.3 cm | Weight | 4.9 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, WEEE, cETLus |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Viewable Size | 21.5" |
Vertical Refresh Rate | 56 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Controls & Adjustments | Volume |
OSD Languages | Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean |
Features | Sync on Green, sRGB colour management, Eco-Mode, SmartContrast, SmartImage, Smart Ergo base, Flicker Free technology, BFR/PVC-free, Mercury free |
Dimensions (WxDxH) | 51.1 cm x 22.7 cm x 48.3 cm - with stand |
Weight | 4.9 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | DisplayPort , DVI-D (HDCP) , VGA , Audio line-in , Headphones |
Mechanical | |
Tilt Angle | -5/+20 |
Swivel Angle | 150 |
Rotation Angle | 90 |
Height Adjustment | 110 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
MTBF | 30,000 hour(s) |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.2 Watt |
Software / System Requirements | |
Included Software | Philips SmartControl Premium |
OS Required | Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 51.1 cm - depth: 22.7 cm - height: 48.3 cm - weight: 4.9 kg , Without stand - width: 51.1 cm - depth: 5.2 cm - height: 31.9 cm - weight: 3.1 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
