BT.com
Wishlist
Peerless-AV SmartMount Universal Flat Wall Mount for 10" to 29" Displays
Peerless-AV SmartMount Universal...
£19.47
31 in stock
£19.47
Add to wishlist
Delivery
Standard 3-5 working days
Ideally suited for small LCD screens, the SmartMount SF630P flat-to-wall mount allows you to mount your LCD screen quickly and easily. The low profile design holds the screen only 25mm away from the wall.
Peerless SmartMount Universal Flat Wall Mount SF630P - mounting kit
Mounting kit
Mounting Components
Wall plate, mounting adapter
15.3 cm x 2.48 cm x 14.6 cm
0.8 kg
Recommended Use
LCD display
Recommended Display Size
10"-29"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
36.3 kg
5 years warranty
15.3 cm
2.48 cm
14.6 cm
0.8 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
10"-29"
Max Load Weight
36.3 kg
Sorted-For-You, scratch-resistant
Limited warranty - 5 years
Scroll to top
