BT.com
Wishlist
Peerless-AV Security Pull-Out Swivel Mount for 32-58" Flat Panel Displays
Peerless-AV Security Pull-Out...
£296.02
Hurry, only 3 left in stock!
£296.02
Add to wishlist
Delivery
Standard 1-3 working days
The SmartMount Pull-Out Swivel Wall Mount combines the best features of a wall mount and a pivot arm. In the closed position, the SP850-UNL acts as a flat or tilting wall mount. At only 3.4" away from the wall, its unique wall plate and built-in cable management neatly hide all components and cords. Extended, the SP850's sturdy arm construction smoothly glides the screen out 11.9" from the wall and allows the screen to pivot up to 45 degrees. This feature not only enables the screen to be positioned for an optimal viewing angle, but it also provides easy access to the back of the screen for maintenance. The SP850-UNL is also ideal in applications where the screen needs to be recessed into a cubby hole, custom frame or aligned into a video wall. Mounts to 16" wood studs, concrete or cinder block.
Peerless SmartMount Pull-out Swivel Mount SP850-UNL - wall mount (Tilt & Swivel)
Wall mount (Tilt & Swivel)
78.1 cm 45.7 cm
9.1 kg
Recommended Use
LCD / plasma panel
Recommended Display Size
32"-80"
Max Mounting Pattern Size
729 x 433 mm
Max Load Weight
68.2 kg
Material
Steel
5 years warranty
78.1 cm
45.7 cm
9.1 kg
Material
Steel
AV Furniture
Wall mount
Mounting Components
Adapter plate, swivel wall mount
Design
Tilt & Swivel
Recommended Use
LCD / plasma panel
729 x 433 mm
32"-80"
Max Load Weight
68.2 kg
Limited warranty - 5 years
Scroll to top
