BT.com
Wishlist
Peerless-AV Peerless Paramount Flush Ceiling Projector Mount PPF-W - mounting kit ( Tilt & Swivel ) - (White)
Peerless-AV Peerless Paramount...
£53.32
3 in stock
£53.32
Add to wishlist
Delivery
Standard 3-5 working days
Peerless' Paramount flush ceiling projector mount is a low profile design ideal for flush mount installations with the Spider universal adaptor plate fitting most projector models.
Peerless PARAMOUNT Flush Ceiling Projector Mount PPF-W - mounting kit (Tilt & Swivel)
Mounting kit (Tilt & Swivel)
Mounting Components
Adapter plate, pivot/roll bracket, swivel assembly
19.7 cm
Adjustable Width
18-42 cm
Adjustable Depth
18-42 cm
Tilt
1.4 kg
Recommended Use
Projector
Max Load Weight
22.6 kg
Material
Cold-rolled steel
White
5 years warranty
DAVIS CinemaTen; DPI iVision Series HD, SX, SX+; Dream Vision DreamWeaver 2; Dukane ImagePro 80XX, 87XX, 8801; JVC DLA-G1000; Liesegang DV 880; Planar PD7010, PD7130; PR Line PR5022; Samsung SP-A800; Vidikron Vision Model 60; Vivitar DP-1100, 1200; Yokogawa D-2300; Zenith DSV-110, DXG-210
19.7 cm
Adjustable Width
18-42 cm
Adjustable Depth
18-42 cm
1.4 kg
Material
Cold-rolled steel
White
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
Projector
Tilt
Max Load Weight
22.6 kg
Scratch-resistant, swivel adjustment
Limited warranty - 5 years
3M Digital Projector S10, S20, S55i, X20, X62, X70, X90w , 3M MP 7630, 7640, 7740, 7760, 8647, 8649, 8755, 8790 , Acer PD 726W , Barco BarcoReality 6400i, 6500 , BOXLIGHT XP 55m , Canon LV-7210, 7240, 7555F, S3 , Casio XJ-560 , DAVIS CinemaOne PRO , DAVIS CinemaTen , DAVIS DL 450, S8, X10, X650 , Dell 2200MP , DPI iVision Series HD, SX, SX+ , Dream Vision DL 500 StarLight , Dream Vision DreamWeaver 2 , Dukane ImagePro 7100HC, 8039A, 8039B, 8043, 8049B, 8063, 8742, 8753, 8753A, 8756, 8756A, 8758, 8801A, 8915 , DWIN TransVision TV2 , Elmo EDP S-10 , Epson PowerLite 503C, 6100i, 71c, 811p , InFocus LP 690 , JVC DLA-G1000, G11U, M2000SC , Kodak Digital Projector DP1050, DP1100, DP850, DP900 , Kodak V 600, 600 Zoom , Liesegang DV 225, 325, 340, 360, 390, 410, 445, 465, 550, 560 flex, 880 flex , Liesegang Solid Cinema , LUXEON L713V, P680, V1, X2, X2 Plus , Microtek CX4 Digital Projector , NEC MultiSync MT830 Plus , Optoma EP725 , Optoma EzPro 610, 615H , Planar PD7010, PD7130 , Planar PR Line PR5022 , Proxima UltraLight S520 , Samsung SP-A800B , Sanyo PLC-SW20, XP40L , Sim2 Grand Cinema HT200 DM, HT200 DMF, HT300 XTRA , Vidikron Vision Model 60 , Vivitar DP-1100s, DP-1200X , Xerox DP 1011 , Yamaha LPX-500, LPX-510 , Yokogawa D-2300X , Zenith DSV-110, DXG-210
Scroll to top
