From boardroom to classroom, the EX531 delivers bright, high contrast presentations and images with crystal clarity. Vibrant, life-like colors using BrilliantColor technology will ensure your audience is left speechless every time the EX531 is turned on. The environmentally friendly EX531 has energy saving features including <1W standby mode. Long lamp-life of 4000hrs combined with the unique Optoma color guarantee saves you both time and money whilst ensuring hassle-free, long lasting projection.
Product Description | Optoma EX531P - DLP projector - portable | Device Type | DLP projector | Brightness | 2600 lumens | Contrast Ratio | 3000:1 | Resolution | XGA (1024 x 768) | Native Aspect Ratio | 4:3 | Colour Support | 1.07 billion colours | Bulb type | 185 Watt | Bulb life cycle | Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode | Video Input | RGB, S-Video, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC) | Video Modes | 480p, 720p, 1080i, 480i, 576i, 576p | Video Output | RGB | Speakers | Speaker(s) - integrated | Power | AC 120/230 V (50/60 Hz) | Power Consumption Operational | 233 Watt | Dimensions (WxDxH) | 28.6 cm x 19.2 cm x 8.4 cm | Weight | 2.3 kg |
General | |
Projector | |
Image Size | 70 cm - 770 cm |
Projection Distance | 1.2 m - 12 m |
Throw Ratio | 1.95 - 2.15:1 |
Uniformity | 80 % |
Resolution | XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized) |
Max Sync Rate (V x H) | 85 Hz x 91.1 kHz |
Controls & Adjustments | Keystone correction |
Features | BrilliantColor |
Lens | |
Lens Aperture | F/2.41-2.55 |
Zoom Type | Manual |
Zoom Factor | 1.1x |
Keystone Correction Direction | Vertical |
Vertical Keystone Correction | -40 / +40 |
Video Input | |
TV System | PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC |
Analogue video Signal | RGB, S-Video, composite video, component video |
Video Interfaces | VGA, composite video, S-Video |
Video Output | |
Analogue Video Signal | RGB |
Speakers | |
Type | Integrated |
Sound Output Mode | Mono |
Output Power / Channel | 2 Watt |
Speakers | 1 x mixed channel |
Input Device | |
Type | External |
Movement Detection Technology | Infrared |
Expansion / Connectivity | |
Interfaces | 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - mini-phone 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone 3.5 mm , 1 x serial RS-232 (management) , 1 x component video / RGB / SCART - 15 pin HD D-Sub (HD-15) |
Miscellaneous | |
Included Accessories | Carrying case, lens cover, wireless remote control |
Cables Included | 1 x VGA cable |
Security Features | Security lock slot (cable lock sold separately), password protection, security bar |
Compliant Standards | RoHS |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational (Standby) | 1 Watt |
Dimensions & Weight | |
Width | 28.6 cm |
Depth | 19.2 cm |
Height | 8.4 cm |
Weight | 2.3 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - lamp - 6 months |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Sound Emission | 30 dB |
Sound Emission (Economic Mode) | 28 dB |
