The LS7200’s low-profile form contains a multi-driver array fed by a slim external amp connected via a single cable, reproducing Dolby Atmos® and DTS:X™ soundtracks with conviction. Effects move from channel to channel, immersing you in multidimensional sound, while music streamed wirelessly with DTS Play-Fi®*1, AirPlay®, or Wi-Fi® has substance that others can’t match. Players connect to the receiver’s four HDMI® inputs and wiring is concealed inside your entertainment unit for a near-invisible install. With a vast choice of entertainment within Onkyo Controller app (including multi-room audio), the LS7200 makes life better with sound tailored to you.
Product Description | Onkyo Envision Cinema LS7200 - home theater sound bar system - 5.1 channel | Product Type | Home theater sound bar system | Components | Speaker system, AV network receiver | Enclosure Colour | Black | Audio Channels | Surround Sound | Audio Specifications | Amplifier 80 dB | Decoders | Dolby Surround, DTS 96/24, Dolby Digital, DTS decoder, DTS Express, Dolby Digital Plus, DSD decoder, Dolby TrueHD, DTS-HD Master Audio, DTS-HD High Resolution, Dolby Atmos, DTS:X, DTS Neural:X | Video Conversion/Scaling | HDMI to HDMI scaling | Surround Sound Effects | Theatre-Dimensional Virtual Surround | Sound Effects | CinemaFILTER | Surround System Class | 5.1 channel | Source | Network, USB-host, Bluetooth | Audio Formats | WAV, WMA, AAC, AIFF, MP3, FLAC, Apple Lossless, LPCM, DSD | Radio System | FM | Streaming Services | Pandora, Deezer, Spotify, TuneIn, TIDAL | Interfaces | Ethernet, Fast Ethernet, Wi-Fi, Bluetooth | Speakers | 1 x sound bar - external - 100 - 20000 Hz , 1 x subwoofer - external - 50 Watt - 30 - 200 Hz | Power | AC 120/230 V (50/60 Hz) |
General | |
Audio System | |
3D Technology | Yes |
Functions | Digital player, AV receiver, network audio player |
Digital Sound Processor (DSP) | Yes |
DSP Presets | Enhanced, All Ch Stereo, TV Logic, Action, Sports, Mono, Full Mono, Multichannel |
Audio Specifications | Amplifier SNR - 80 dB |
Input Impedance | 47 kOhm |
Input Sensitivity | 200 mV |
Amplifier Output details | 50 Watt - 4 Ohm - at 1 kHz - THD 1% - 1 channels |
Bass Control | Yes |
Treble Control | Yes |
Digital Content Protection | HDCP 2.2 |
Features | Multi-room audio output, Bluetooth Audio Streaming, Audio Return Channel (ARC), Apple AirPlay support, iPod/iPhone/iPad ready, smartphone remote controlled, x.v.Color, Deep Colour, AccuEQ room acoustic calibration, DTS Play-Fi Technology |
Signal Processing Features | |
HDMI Pass-Through | Up to 4K |
Upscaling via HDMI | Up to 4K |
Speaker System | |
Speakers | 1 x sound bar - external - 100 - 20000 Hz - 4 Ohm - 78 dB/Watt - wired , 1 x subwoofer - external - 50 Watt - 30 - 200 Hz - wireless |
Driver Details | Subwoofer: 1 x subwoofer driver - 6.3" , Sound bar: 6 x full-range driver - 2.76 x 1.57" , Sound bar: 2 x full-range driver - 2.28" |
Radio System | |
Type | FM - digital radio tuner |
Tuner Frequency Range | FM: 87.5 - 108 MHz |
FM Preset Station Qty | 40 preset stations |
Supported RDS Functions | PTY, RT |
Network & Internet Multimedia | |
Connections | |
Connectors | 4 x HDMI input (19 pin HDMI Type A) - rear , HDMI output (19 pin HDMI Type A) - rear , Network (RJ-45) - rear , Digital audio input (optical) (TOS Link) - rear , Audio line-in (RCA x 2) - rear , USB (4 PIN USB Type A) - front , Headphones (mini-phone stereo 3.5 mm) - front |
Miscellaneous | |
Included Accessories | Remote control, FM antenna, 2 AAA batteries, auto calibration microphone, speaker cable kit |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Dimensions & Weight | |
Dimensions (WxDxH) / Weight | AV network receiver: 43.5 cm x 32.55 cm x 7 cm / 4 kg , Speaker system: sound bar: 95 cm x 8 cm x 5.5 cm / 2.3 kg , Speaker system: subwoofer: 26.1 cm x 26.9 cm x 33.8 cm / 6.2 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 109.8 cm |
Depth (Shipping) | 51.8 cm |
Height (Shipping) | 35.4 cm |
Weight (Shipping) | 18 kg |
