Application data, virtual images, client files, email, the types of data central to running a successful business can seem endless. With ReadyNAS you finally have an advanced and easy-to use solution for centralizing, securing and controlling access to your digital assets. Way more than just simple unified (NAS and SAN) storage for your company, ReadyNAS allows you to do more than you ever thought you could afford by pairing the latest in performance with innovative efficiency technologies such as unlimited snapshots, thin provisioning and cloud-managed replication.
Product Description | NETGEAR ReadyNAS 2120 RN21241D - NAS server - 4 TB | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Enclosure Type | Rack-mountable - 1U | Total Storage Capacity | 4 TB | Max Supported Capacity | 16 TB | Installed Devices / Modules Qty | 4 (installed) / 4 (max) | Dimensions (WxDxH) | 43 cm x 30.8 cm x 4.4 cm | Weight | 7.48 kg () | Processor | 1 x Marvell ARMADA 1.6 GHz (Dual-Core) | Storage Controller | 1 x RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD | Hard Drive | 4 x 1 TB | Networking | 10Mb LAN, 100Mb LAN, 1GbE | RAM | 2 GB | Power | AC 120/230 V (50/60 Hz) | Storage Operating System | RAIDiator OS | Manufacturer Warranty | 5-year warranty |
General | |
Width | 43 cm |
Depth | 30.8 cm |
Height | 4.4 cm |
Processor / Memory | |
Processors Installed | 1 x Marvell ARMADA 1.6 GHz |
Number of Cores | Dual-Core |
RAM | 2 GB |
Flash Memory Installed | 128 MB |
Storage Controller | |
Type | 1 x RAID |
Interface Type | SATA 3Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD |
Hard Drive | |
Type | HDD - hot-swap - 2.5" / 3.5" shared |
Capacity | 4 x 1 TB |
Compliant Standards | S.M.A.R.T. |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, 1GbE |
Network / Transport Protocol | NTP, DHCP, Bonjour |
Remote Management Protocol | SNMP 2, SNMP 3, SSH |
Network Services Compatibility | Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS |
Features | Dynamic IP address assignment, load balancing, VLAN support, wake on LAN (WOL), E-mail alert, LACP support, DHCP client, WebDAV server |
Compliant Standards | IEEE 802.3ad (LACP) |
Expansion / Connectivity | |
Expansion Bays | 4 (total) / 0 (free) x hot-swap - 2.5" / 3.5" |
Interfaces | 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 , 1 x USB 2.0 , 2 x eSATA |
Miscellaneous | |
Features | X-RAID2 technology |
Compliant Standards | FCC Class B certified, RoHS, VCCI Class B |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
