We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The NETGEAR SOHO Ethernet switches provide easy and affordable network connectivity to small offices and home/offices. They are easy to use, reliable, and rugged with metal enclosures. With these Plug-n-play switches, you can quickly and easily expand your network connections to multiple devices, with no configuration required. These switches also support various energy saving technologies, helping you save power and money.
Product Description | NETGEAR SOHO Gigabit Ethernet Switch GS308P - switch - 8 ports - unmanaged | Device Type | Switch - 8 ports - unmanaged | Subtype | Gigabit Ethernet | Ports | 4 x 10/100/1000 (PoE) + 4 x 10/100/1000 | Power Over Ethernet (PoE) | PoE | PoE Budget | 53 W | Performance | Bandwidth: 16 Gbps | MAC Address Table Size | 4K entries | Jumbo Frame Support | 9720 bytes | Features | Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), Quality of Service (QoS), Green Ethernet, fanless, Energy Efficient Ethernet, security lock slot (cable lock sold separately), 1.5MB packet buffer | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3az | Dimensions (WxDxH) | 15.8 cm x 10.1 cm x 2.9 cm | Weight | 460 g | Localisation | United Kingdom | Manufacturer Warranty | 3-year warranty |
General | |
Enclosure Type | Desktop, wall-mountable |
PoE Budget | 53 W |
Status Indicators | Power, PoE, link/activity |
Expansion / Connectivity | |
Interfaces | 4 x 1000Base-T RJ-45 PoE - 15.4 W , 4 x 1000Base-T RJ-45 |
Power | |
Power Device | External power adapter |
Power Consumption Operational | 60 Watt |
Miscellaneous | |
MTBF | 2,244,211 hours |
Compliant Standards | CB, CCC, FCC Part 15 A |
Dimensions & Weight | |
Width | 15.8 cm |
Depth | 10.1 cm |
Height | 2.9 cm |
Weight | 460 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 95% |
