The NETGEAR 300 Series Unmanaged Switches provide easy and affordable network connectivity to home and small offices. They are easy to use and reliable. With these Plug-and-Play switches, you can expand your network connections to multiple devices instantly. The 300 series also support the efficient use of energy, helping you save power and money.
Product Description | NETGEAR GS308v3 - switch - 8 ports - unmanaged | Device Type | Switch - 8 ports - unmanaged | Subtype | Gigabit Ethernet | Ports | 8 x 10/100/1000 | Performance | Bandwidth: 16 Gbps , Forwarding performance (64-byte packet size): 1448000 pps | Capacity | Packet buffer size: 128 | MAC Address Table Size | 8K entries | Jumbo Frame Support | 9216 bytes | Features | Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), Quality of Service (QoS), fanless, Energy Efficient Ethernet, SOHO (Small Office/Home Office), Weighted Round Robin (WRR) | Compliant Standards | IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az | Dimensions (WxDxH) | 15.8 cm x 10.1 cm x 2.9 cm | Weight | 390 g | Manufacturer Warranty | 3-year warranty |
General | |
Enclosure Type | Desktop, wall-mountable |
Status Indicators | Power, link/activity |
Expansion / Connectivity | |
Interfaces | 8 x 1000Base-T RJ-45 |
Power | |
Power Device | External power adapter |
Power Consumption Operational | 3.04 Watt |
Power Consumption Stand by | 0.36 Watt |
Miscellaneous | |
MTBF | 3,711,898 hours |
Compliant Standards | Plug and Play, IC Class B, VCCI, CB, FCC Part 15 B, CCC, LVD, KC, RCM |
Dimensions & Weight | |
Width | 15.8 cm |
Depth | 10.1 cm |
Height | 2.9 cm |
Weight | 390 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 90% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 95% (non-condensing) |
