The 3rd generation Nest Learning Thermostat
A thinner, sleeker design. A bigger, sharper display. And hot water control. The Nest Thermostat gets to know the temperature you like when you’re at home and turns itself down when you’re away. So it saves energy. That’s the most beautiful part.
Product Description | Nest Learning Thermostat 3rd generation - thermostat - 802.11b/g/n, Bluetooth 4.0, 802.15.4 - white | Product Type | Thermostat | Sensor Type | Temperature, humidity, ambient light | Functions | Control heating systems, control cooling systems | Internet of Things (IoT) Platform | Nest | Intelligent Assistant | Google Assistant, Alexa - indirect | Connectivity | Wireless - 802.11b/g/n, Bluetooth 4.0, 802.15.4 | Supported Host Device OS | iOS, Android | Display | 2.08" - LCD | Colour | White | Localisation | United Kingdom | Manufacturer Warranty | 2-year warranty | Dimensions (WxDxH) | 8.4 cm x 3.08 cm x 8.4 cm |
General | |
Connectivity Technology | Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0 |
OS Required | Microsoft Windows 7 or later, Apple MacOS X 10.9 or later |
Supported Host Device OS | Android 4.0 (Ice Cream Sandwich) or later, iOS 8.0 or later |
Features | Wall mountable |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Platform | Nest |
Intelligent Assistant | Google Assistant, Alexa |
Voice Controlled | Indirect |
Thermostat | |
Modes | Auto, manual, programme |
Features | Backlit display |
Battery | |
Rechargeable Battery | Rechargeable |
Technology | Lithium Ion |
Miscellaneous | |
Included Accessories | Mounting kit |
Colour | White |
Dimensions & Weight | |
Width | 8.4 cm |
Depth | 3.08 cm |
Height | 8.4 cm |
Weight | 244 g |
