Talk, play and browse longer than ever with the new mophie powerstation XXL universal battery. This 20,000mAh universal battery is packed with more power then ever. Get more than seven additional charges on your smartphone or get up to two extra charges on your tablet. Three USB ports let you charge multiple devices. The compact design and premium aluminum finish make this model easy to carry.
mophie products go through rigorous testing. Each battery is tested three times to ensure peak performance and safe operation. This is the reason why mophie is the #1 and most trusted brand in portable power.
Product Description | mophie powerstation XXL power bank - USB | Product Type | Power bank | Dimensions (WxDxH) | 9.2 cm x 2 cm x 15.5 cm | Weight | 428 g | Colour | Space grey | Output Connector Type | Total 3: USB - on cable: Micro-USB | Max Electric Current | 2.1 A | Battery | 20000 mAh | Power Device Details | 2 x - 4 pin USB Type A - 2.1 A , - 4 pin USB Type A - 1 A | Cables | Micro-USB cable | Manufacturer Warranty | 2-year warranty |
General | |
Width | 9.2 cm |
Depth | 2 cm |
Height | 15.5 cm |
Weight | 428 g |
Enclosure Colour | Space grey |
Power Device | |
Input Connectors | 5 pin Micro-USB Type B |
Input Connectors Qty | 1 |
Output connectors | Total 3: 4 pin USB Type A |
Detachable Cable Connector Type | Micro-USB Type B |
Power Device Details | 2 x 4 pin USB Type A - 2.1 A , 4 pin USB Type A - 1 A |
Features | Temperature protection, short circuit protection, overcharging protection, power LED Indicator |
Battery | |
Capacity | 20000 mAh |
Miscellaneous | |
Material | Aluminium |
Cables Included | Micro-USB cable |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
