Surface Laptop provides the perfect blend of texture, subtle details, and clean, elegant lines - plus the luxurious touch of the Signature Alcantara material-covered keyboard. You don't have to choose between power and traveling light. At just 2.76 pounds, Surface Laptop gives you an ideal balance of both, plus all-day battery life.
Product Description | Microsoft Surface Laptop - 13.5" - Intel Core i7 - 7660U - 16 GB RAM - 512 GB SSD - UK | Product Type | Notebook | Operating System | Win 10 Pro | Processor | Intel Core i7 (7th Gen) - 7660U / 2.5 GHz, up to 4 GHz / 4 MB Cache | Memory | 16 GB LPDDR3 | Storage | 512 GB SSD | Display | 13.5" touchscreen 2256 x 1504 - 201 ppi | Graphics | Intel Iris Plus Graphics 640 | Input Device | Trackpad | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1 | Battery | Up to 14.5 hours | Features | Ambient light sensor | Dockable | Yes | Security | Trusted Platform Module (TPM 2.0) Security Chip | Colour | Graphite gold | Dimensions (WxDxH) | 30.81 cm x 22.327 cm x 1.448 cm | Weight | 1.283 kg | Pricing Type | Commercial | Specific Absorption Rate (SAR) | 0.18 W/kg (body) | Manufacturer Warranty | Limited warranty - 1 year |
General | |
Operating System | Windows 10 Pro |
Processor / Chipset | |
CPU | Intel Core i7 (7th Gen) 7660U / 2.5 GHz |
Max Turbo Speed | 4 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 16 GB |
Technology | LPDDR3 SDRAM |
Speed | 1866 MHz |
Storage | |
Main Storage | 512 GB SSD |
Display | |
Type | 13.5" |
Touchscreen | Yes (10-point multi-touch) |
Resolution | 2256 x 1504 |
Widescreen | Yes |
Pixel Density (ppi) | 201 |
Image Aspect Ratio | 3:2 |
Colour Gamut | 100% sRGB |
Features | Corning Gorilla glass 3, PixelSense |
Audio & Video | |
Graphics Processor | Intel Iris Plus Graphics 640 |
Camera | Yes - 720p |
Camera Features | Windows Hello |
Sound | Stereo speakers, stereo microphone |
Compliant Standards | Dolby Audio Premium |
Input | |
Type | Keyboard, trackpad |
Keyboard Layout | UK |
Features | Soft-touch surface, multi-gesture trackpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Battery | |
Run Time | Up to 14.5 hours |
AC Adapter | |
Output | 44 Watt |
Connections & Expansion | |
Interfaces Details | USB 3.0 , Mini DisplayPort , Headphone/microphone combo jack , SurfaceConnect (magnetic power and docking) |
Miscellaneous | |
Case Material | Aluminum |
Integrated Options | Ambient light sensor |
Dockable | Yes |
Included Accessories | Power adapter |
SAR Value | 0.18 W/kg (body) |
Dimensions & Weight | |
Weight | 1.283 kg |
Sustainability Information | |
TCO Certified | - |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
