High-quality content
Showcase your important presentations in the best possible way with the EB-4770W. Thanks to Epson's 3LCD technology, you can be sure that your projected images will feature accurate colours and clear detail. Your images will continue to look their best even in brightly-lit rooms thanks to high brightness and an equally high White and Colour Light Output.
Flexible connectivity
Bring your presentations to life with a range of high-definition content, which can be projected from a variety of devices connected via the HDMI and DisplayPort inputs. Content from these devices can also be displayed alongside content from another source, such as a separate laptop or Epson USB Visualiser, using the side-by-side split screen function.
Easy set-up and maintenance
Setting up the projector is quick and easy thanks to a variety of user-friendly installation features, meaning you can get started quickly. You can place the projector in a number of positions without fear of blurring or distorting the image thanks to its x1.8 wide zoom ratio, keystone correction and arc and point correction. We have also made it easy for you to keep your projections as bright and clear as possible. Both the lamp and filter are easy to replace, meaning maintenance is quick and straightforward.
Product Description | Epson EB-4770W - LCD projector - LAN | Device Type | LCD projector - 720p | Built-in Devices | Speaker | Brightness (White) | 5000 lumens | Brightness (Colour) | 5000 lumens | Contrast Ratio | 5000:1 (dynamic) | Resolution | WXGA (1280 x 800) | Native Aspect Ratio | 16:10 | Lens Shift Direction | Horizontal, vertical | Bulb type | UHE 280 Watt | Bulb life cycle | Up to 4000 hours - normal mode , Up to 5000 hour(s) - economic mode | Video Input | RGB, S-Video, composite video, component video LAN | Speakers | Speaker(s) - integrated | Power | AC 120/230 V (50/60 Hz) | Power Consumption Operational | 388 Watt | Dimensions (WxDxH) | 47.2 cm x 35.4 cm x 15.9 cm | Weight | 6.6 kg | Manufacturer Warranty | 3-year warranty |
General | |
Networking | Ethernet |
Projector | |
Brightness (Reduced) | 3000 lumens |
Image Size | 76 cm - 762 cm |
Projection Distance | 1.4 m - 15 m |
Throw Ratio | 1.26 - 2.3:1 |
Resolution | WXGA - WXGA (1280 x 800) |
Features | sRGB colour profile, EPSON Quick Corner, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode |
Lens | |
Focus Type | Manual |
Lens Aperture | F/1.65-2.55 |
Zoom Factor | 1.8x |
Keystone Correction Direction | Horizontal, vertical |
Vertical Keystone Correction | -30 / +30 |
Horizontal Keystone Correction | -30 / +30 |
Vertical Lens Shift | 50% / 50% |
Horizontal Lens Shift | 10% / 10% |
Video Input | |
Analogue video Signal | RGB, S-Video, composite video, component video |
Video Interfaces | VGA, HDMI, DisplayPort, component video, composite video, S-Video |
LAN and Wireless Image Transferring Protocols | Wired LAN |
Speakers | |
Type | Integrated |
Output Power / Channel | 10 Watt |
Expansion / Connectivity | |
Interfaces | 1 x component video input - BNC x 5 , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - mini-DIN , 1 x HDMI input - 19 pin HDMI Type A , 1 x DisplayPort input , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin USB Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x network - RJ-45 , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) |
Miscellaneous | |
Included Accessories | Cable cover, wireless remote control |
Cables Included | 1 x VGA cable |
Security Features | Security lock slot (cable lock sold separately), lens lock |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Stand by | 0.39 Watt |
Software / System Requirements | |
Software Included | Drivers & Utilities, EasyMP Network Projection, EasyMP Monitor |
Dimensions & Weight | |
Width | 47.2 cm |
Depth | 35.4 cm |
Height | 15.9 cm |
Weight | 6.6 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours |
Environmental Parameters | |
Humidity Range Operating | 20 - 80% |
Sound Emission | 38 dB |
Sound Emission (Economic Mode) | 32 dB |
