Payday Tech Sale: The Biggest Brands. The Biggest Savings. Treat yourself to some new tech.
Logitech PC 960 Stereo Headset USB For Business
£29.08
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Stylish, adjustable over-the-head design helps ensure a comfortable fit that won't slip off
  • Ultra-soft earpad, flexible and lightweight design enable all-day wear
  • Adjustable microphone for precise positioning
  • Microphone rotates out of the way when listening to music
  • Adjust the volume or mute the microphone, right from the headset
  • Microphone mute indicator light tells you when mute is enabled
  • Recommended Use: Computer, Office
  • Connectivity: Wired
  • Earcover : Binaural
Product codes
Documents
chevron icon
chevron icon
The Logitech® PC Headset 960 USB features a comfortable and lightweight headband with volume controls and adjustable boom microphone . The noise-canceling microphone filters unwanted background noise. Ships in a business pack.
Stylish, adjustable over-the-head design for a comfortable fit that won't slip off. Ultra-soft earpad, flexible and lightweight design ensures all-day comfort. USB cable for simple, plug-and-play connectivity. Adjustable boom microphone for precise positioning; the microphone rotates out of the way when not in use. In-line volume or mute controls for easy and precise control. Microphone mute indicator light tells you when mute is enabled. Advanced digital USB delivers superior stereo sound quality. Noise-canceling microphone filters background noise for clearer conversations. White-box business packaging is easy to ship, store and recycle. 3-Year warranty.
The Logitech® PC Headset 960 USB features a comfortable and lightweight headband for all day wear, with in-line controls for volume and mute adjustment. The boom microphone can be adjusted to the optimal position for clearer conversations. The noise-cancelling microphone filters backgound noise, and rotates out of the way when not in use. Ships in a business pack ideal for system builders, integrators and value-added resellers
chevron icon
Product Description Logitech PC Headset 960 USB - headset
Product Type Headset - wired
Recommended Use Computer
Headphones Form Factor On-ear binaural
Connectivity Technology Wired
Headphones Technology Dynamic
Sound Output Mode Stereo
Audio Specifications Frequency Response 20 - 20000 Hz
Microphone Boom
Controls Volume, microphone on/mute
chevron icon
Resources
The following resources are available for the Logitech PC 960 Stereo Headset USB For Business
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£29.08
