ITEM | QTY | PRICE |
Lenovo ThinkPad USB 3.0 Secure HDD-500GB
3 | £515.19 |
Crucial 16GB DDR4 3200 MHz DIMM CL22...
4 | £136.20 |
HP HP 305 2-PACK TRI-COLOR/BLACK
4 | £77.88 |
Logitech's advanced trackball for trackball enthusiasts and consumers, searching for alternatives to mice and touchpads. Delivers less muscular strain. MX ERGO features a unique adjustable hinge for personalized comfort and the tracking, scrolling and power management technology. Logitech FLOW enables effortless cross computer control.
Product Description | Logitech MX ERGO - trackball - Bluetooth, 2.4 GHz | Device Type | Trackball | Connectivity Technology | Wireless - Bluetooth, 2.4 GHz | Dimensions (WxDxH) | 9.98 cm x 13.25 cm x 5.14 cm | Weight | 259 g | Wireless Receiver | USB wireless receiver | Movement Detection Technology | Optical | Buttons Qty | 8 | Movement Resolution | 440 dpi | Features | Scrolling wheel, Logitech Advanced Optical Tracking | OS Required | Microsoft Windows 7 / 8 / 10, Apple macOS 10.12 | Manufacturer Warranty | 2-year warranty |
General | |
Width | 9.98 cm |
Depth | 13.25 cm |
Height | 5.14 cm |
Weight | 259 g |
Input Device | |
Connectivity Technology | Wireless |
Interface | Bluetooth, 2.4 GHz |
Max Operating Distance | Up to 10 m |
Buttons Qty | 8 |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Included Accessories | Micro-USB cable |
Battery | |
Technology | Lithium polymer |
Capacity | 500 mAh |
Run Time (Up To) | 4 months |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
