Click to visit BT.com
BT.com
Wishlist
Linksys Dual-Band Wireless-N USB Adapter
Quicklinx: 8DPDWS00
Mfr#: AE2500-EU
Wired / Wireless: Wireless
Protocol: IEEE 802.11n
Form Factor: External
Compatibility: PC
Type: Network adapter
Express delivery Order within the next 14 hours for delivery tomorrow
Hurry, only 1 left in stock!
£17.48
Built with leading 802.11n wireless technology, the Linksys AE2500 offers optimal coverage and reliability. Multiple MIMO (multiple input multiple output) antennas boost signal strength so you can enjoy dependable wireless connectivity whether at home or at Wi-Fi hotspots on the go.
Improve your wireless performance with dual-band N (operates at 2.4 or 5 GHz) designed to avoid interference and maximize throughput for smoother and faster video streaming, file transfers, and wireless gaming. Keep Wi-Fi freeloaders and Internet threats at bay with the latest in WPA2 security to help keep your network protected. The included setup wizard installs your adapter quickly and makes going wireless easy.
Enhance your computer with the flexibility and high performance of dual-band wireless-N. Just plug the Adapter into your computer's USB port to wirelessly connect to a network or hotspot. With transfer rates up to 300 Mbps you'll enjoy a powerful networking experience for surfing, chatting, sharing, or playing online.
High Speed
Enhance your computer with the flexibility and high performance of Dual-Band Wireless-N. Just plug the Adapter into your computer?s USB port to wirelessly connect to a network or hotspot. With transfer rates up to 300 Mbps you?ll enjoy a powerful networking experience for surfing, chatting, sharing, or playing online.
Quick to Install
Set up your Adapter in a few quick steps with a simple Setup Wizard.
Superior Wireless Range
The Power of Dual-Band
Advanced Security
Easy Setup
Header / Manufacturer
Linksys
Header / Model
AE2500 Dual-Band Wireless-N USB Adapter
Network adapter
Wired / Wireless
Wireless
Header / Packaged Quantity
1
Speed
300 Mbps
Standards
IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Miscellaneous / Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA-Enterprise, WPA2, WPA2-Enterprise
Service & Support / Type
2 years warranty
Header / Country Kits
Europe
External
Hi-Speed USB
System Requirements / OS Required
Microsoft Windows 7, Microsoft Windows Vista SP1, Microsoft Windows XP SP3
Compatibility
PC
Dimensions & Weight / Height
0.9 cm
Dimensions & Weight / Width
7.3 cm
Dimensions & Weight / Depth
2.4 cm
Dimensions & Weight / Weight
11 g
Linksys Dual-Band Wireless-N USB Adapter Bundle deal on Linksys Dual-Band Wireless-N USB Adapter
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£27.47
saving £4.99
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £4.98 | in stock
£21.57
saving £0.88
Compatibility: PC
Brand: Linksys
Price Range Inc VAT: 0 - 50
