55" LG ULTRA HD 4K TV
The Ultra HD innovation is built into the unique IPS 4K panel meaning your entertainment is viewable from any angle without distortion.
Advanced formatting technology enables LG UHD TV to output many recognized High Dynamic Range algorithms, such as HLG and HDR 10. Get the HDR experience from more HDR sources.
Make the ordinary, extraordinary. Advanced picture processing produces an HDR effect for standard dynamic range content. Lift your ordinary entertainment to a new level of color and contrast.
Product Description | LG 55UJ670V 55" LED-backlit LCD TV - 4K | Product Type | LED-backlit LCD TV - Smart TV | Diagonal Class | 55" | Platform | webOS 3.5 | Resolution | 3840 x 2160 | Display Format | 4K UHD (2160p) | HDR Format | HLG10 | HDR Technology | Active HDR | Frame Rate & Enhancement Technology | TruMotion 100Hz, 50 Hz Refresh Rate | Video Interface | Component, composite, HDMI | HDMI Ports Qty | 4 ports | Connectivity | Wi-Fi, LAN, Bluetooth | Technology | IPS | LCD Backlight Technology | Edge-lit LED local dimming | Image Aspect Ratio | 16:9 | Digital TV Tuner | DVB-C, DVB-S2, DVB-T2 | Picture Enhancements | 4K Upscaling, Resolution Upscaler, True Colour Accuracy, Color Master Engine, Active Depth Enhancer, Upscaller HDR, wide colour gamut technology | Speaker System | 2 speakers | Sound Effects | ULTRA Surround | Platform | SmartThinQ | USB | 2 ports | Included Accessories | Remote control | Voltage | AC 120/230 V (50/60 Hz) | Energy Class | Class A+ | Power Consumption (On mode) | 85 W | Power Consumption Stand by | 0.3 Watt | Energy Consumption per Year | 118 kWh | Dimensions (WxDxH) - without stand | 123.7 cm x 6.38 cm x 71.8 cm | Weight | 16 kg |
General | |
HDR Capable | Yes |
Video Processor | Quad-Core |
TV Tuner Presence | Yes |
Sensors | White sensor |
Modes | Hotel mode |
Design | Metal frame |
Dimensions | Without stand |
Width | 123.7 cm |
Depth | 6.38 cm |
Height | 71.8 cm |
Weight | 16 kg |
Display | |
LCD Display Technology | IPS |
LCD Backlight Technology | Edge-lit LED - local dimming |
Features | Time-shift, My Channel, Ultra Luminance, Magic Zoom, Magic Mobile Connection |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
Flat Panel Mount Interface | 300 x 300 mm |
TV Tuner | |
Conditional Access | Common Interface Plus (CI+) slot |
Digital TV Tuner | |
HDTV Tuner | Yes |
Digital TV Service | HbbTV |
MPEG Profiles and Levels | HEVC/VP9 |
Video Features | |
Teletext | Yes |
Teletext Memory | 2000 pages |
Electronic Programme Guide | Digital EPG |
Media Player | |
Supported Video Formats | MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, AVC, H.264, VC-1, HEVC, VP9, VP8, RV30, RV40 |
Supported Audio Formats | MP3, WMA, PCM, AC3, AAC, HE-AAC, E-AC3, MP2 |
USB Port | Yes |
USB Ports Qty | 2 |
Remote Control | |
Type | Remote control |
Audio System | |
Digital Audio Format | Dolby Digital output, DTS digital output, DTS-HD digital output |
Surround Mode | Yes |
Output Power / Total | 20 Watt |
Features | Bluetooth Audio Streaming, Audio Return Channel (ARC), apt-X audio compression, Smart Sound, Clear Voice III technology |
Speakers | 2 x speaker - 10 Watt |
Network & Internet Multimedia | |
Functionality | WEB browsing, Internet video playback |
LAN Protocol | Ethernet |
Wi-Fi Protocol | 802.11ac |
Connect & Share | Intel Wireless Display (WiDi), Wi-Fi Miracast |
Supported Consumer Electronics Control (CEC) | Simplink |
Application Store | LG Content Store |
DLNA | Yes |
Connections | |
Connector Type | 4 x HDMI , Composite video / component video input , 2 x USB 2.0 , LAN , Digital audio output (optical) |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Miscellaneous | |
Compliant Standards | ERP |
Power | |
Power Device | Power supply |
Input Voltage | AC 120/230 V (50/60 Hz) |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 123.7 cm x 6.38 cm x 71.8 cm x 16 kg , Panel with stand - 123.7 cm x 25.9 cm x 77.2 cm x 17.4 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 136 cm |
Depth (Shipping) | 17.5 cm |
Height (Shipping) | 86 cm |
Weight (Shipping) | 22.5 kg |
