LG SK1 - 2.1 Channel Sound Bar with Bluetooth Connectivity
Key Features
Compact Design
LG TV Sound Sync
Rich Sound in Compact Size
The compact sized all-in-one Sound Bar delivering a great balance of good sound and strong bass.
Bluetooth, stream anything
Wirelessly stream music directly from your smartphone or other compatible device for a seamless listening experience.
Bluetooth Stand-by, wake up your Sound Bar
Sound starts the moment you transfer audio to the Sound Bar. The Sound Bar remains in sleep mode but turns on and begins playing when the audio is sent via Bluetooth.
LG Sound Sync
LG Sound Sync links the Sound Bar to a compatible LG TV using an optical cable.
Product Description | LG SK1 - sound bar - for home theatre - wireless | Product Type | Sound bar - for home theatre | Speaker Type | Active | Nominal Output Power | 40 Watt | Amplifier | Integrated | Interfaces | Bluetooth | Audio Formats | AAC, LPCM, AAC + | Speaker Details | Sound bar - stereo - 2 x 20 Watt - active | Built-in Decoders | Dolby Digital | Sound Effects | Adaptive Sound Control (ASC), Bass Blast | Dimensions (WxDxH) | 65 cm x 8.89 cm x 7.7 cm | Weight | 2 kg | Manufacturer Warranty | 1 year warranty |
General | |
Speaker System | |
Interfaces | Bluetooth 4.0 |
Speaker System Details | |
Connections | |
Connector Type | Audio line-in (mini-phone stereo 3.5 mm) , Digital audio input (optical) , USB |
Miscellaneous | |
Included Accessories | Remote control |
Power | |
Power Source | AC power adapter |
Dimensions & Weight | |
Width | 65 cm |
Depth | 8.89 cm |
Height | 7.7 cm |
Weight | 2 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 72.4 cm |
Shipping Depth | 20.2 cm |
Shipping Height | 13.7 cm |
Shipping Weight | 2.77 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
