Different rooms have different needs, so the dual-speaker design of the LG Sound Bar Flex enables it to be configured in a variety of ways. However you like to enjoy movies and music, this audio package delivers. For maximum enjoyment of various types of programming (movies, sports, games, etc.), LG-exclusive Adaptive Sound Control can automatically detect what's playing and then enhance the clarity and impact of the audio. An outboard wireless subwoofer can drastically improve the cinematic audio experience, adding room-shaking bass to movies and more.
Enhance the home cinema experience without the clutter of unnecessary cables. LG Sound Sync technology links compatible LG televisions to the sound bar wirelessly, using Bluetooth. For even greater versatility, one of the speakers in this LG sound system is Bluetooth-enabled with its own built-in rechargeable battery, allowing it to be placed and enjoyed just about anywhere.
Product Description | LG SJ7 Sound Bar Flex - sound bar system - for home theatre - wireless | Product Type | Sound bar system - for home theatre - 4.1-channel | System Components | 2 speakers, subwoofer | Speaker Type | Active | Amplifier | Integrated | Interfaces | Bluetooth | Audio Formats | PCM | Speaker System Details | 1 x speaker 80 Watt - at 1 kHz - 8 Ohm , 1 x portable speaker 80 Watt - at 1 kHz - 8 Ohm , 1 x subwoofer 160 Watt 3 Ohm | Built-in Decoders | DTS Digital Surround, Dolby Audio | Sound Effects | Adaptive Sound Control (ASC), Bass Blast, Cinema | Battery | Speaker battery rechargeable - Lithium Ion | Manufacturer Warranty | 1-year warranty |
General | |
Design Features | Transformable into a sound bar or rear/front speakers |
Speaker System | |
Multiroom | Yes |
Interfaces | Bluetooth 4.0 |
Additional Features | Transformable into a sound bar |
Speaker System Details | |
Speakers Included | 1 x speaker - 80 Watt - at 1 kHz - 8 Ohm , 1 x portable speaker - 80 Watt - at 1 kHz - 8 Ohm - wireless , 1 x subwoofer - 160 Watt - 3 Ohm - wireless |
Connections | |
Connector Type | HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Digital audio input (optical) (TOS Link) |
Miscellaneous | |
Included Accessories | Remote control, speaker stands, audio (optical) cable |
Power | |
Power Source | AC power adapter, battery |
Battery | |
Type | Rechargeable - Lithium Ion |
Run Time (Up To) | 4 hour(s) |
Dimensions & Weight | |
Dimensions (WxDxH) / Weight Details | Speaker: 34 cm x 11 cm x 7.4 cm , Portable speaker: 34 cm x 11 cm x 7.4 cm , Subwoofer: 17.1 cm x 25.2 cm x 32 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 1 year |
