21:9 UltraWide™ FHD on IPS Display
"21:9 UltraWide™ FHD (2560*1080) display offers visual comfort and ensures your best viewing pleasure. There is no color shift or no distortion of color at all."
The Beauty of ArcLine
Inspired by the beauty and power of nature, the ArcLine completes the design with a refined aesthetic flair.
UltraWide™ FOV Meets FreeSync
Experience fluid motion play on the 21:9 UltraWide™’s generous field of view without screen tearing or stuttering.
Game Mode
"Game Mode, consisting of FPS, RTS, and Custom modes, provides a customized gaming experience that varies with genres."
Fully Geared UP with Winning Features
Black Stabilizer is especially useful to detect objects including enemies that are hiding in dark areas. Dynamic Action Sync allows you to attack enemies faster with less lag time.
Flawless Color Expression
"You are guaranteed an immersive artwork through a sRGB over 99% color space.Color calibration tests are conducted on the production line to ensure color accuracy. "
Up-scaled Work Efficiency
Screen Split and PIP Mode bring you to be the real multi-tasker.
Exceptional Usability
OnScreen Control and My Display Presets allow you to easily customize monitor settings with a few clicks of a mouse.
Product Description | LG 29UM68-P - LED monitor - 29" | Device Type | LED-backlit LCD monitor - 29" | Energy Class | Class B | Energy Consumption per Year | 47 kWh | Power Consumption (On mode) | 32 W | Panel Type | IPS | Aspect Ratio | 21:9 | Native Resolution | 2560 x 1080 | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 5 ms | Colour Gamut | 99% Adobe RGB | Input Connectors | 2xHDMI, DisplayPort | Voltage | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) - with stand | 70.25 cm x 20.47 cm x 41.4 cm | Weight | 5.4 kg | Compliant Standards | Plug and Play | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 29" |
Panel Type | IPS |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 30 - 90 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
OSD Languages | Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean |
Features | Picture Mode, Auto Resolution, On-screen Digital Controls, 4-screen split, Mercury free, MaxxAudio, Black Stabilizer |
Dimensions (WxDxH) | 70.25 cm x 20.47 cm x 41.4 cm - with stand |
Weight | 5.4 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 5 Watt |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort , Headphones |
Mechanical | |
VESA Mounting Interface | 75 x 75 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 31 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 70.25 cm - depth: 20.47 cm - height: 41.4 cm - weight: 5.4 kg , Without stand - width: 70.25 cm - depth: 6.38 cm - height: 32.84 cm - weight: 4.8 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
