The IPS technology highlights the performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can view the screen at virtually any angle.
Product Description | LG 22MP58VQ - LED monitor - Full HD (1080p) - 21.5" | Device Type | LED-backlit LCD monitor - 21.5" | Energy Class | Class B | Energy Consumption per Year | 31 kWh | Power Consumption (On mode) | 21 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.24795 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 72% (CIE 1976) | Input Connectors | HDMI, DVI-D, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 51.01 cm x 18.68 cm x 39.53 cm | Weight | 2.9 kg | Compliant Standards | Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI, ERP, EPA 6.0 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 21.5" |
Panel Type | IPS |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
OSD Languages | Hindi, Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean |
Features | Picture in picture, HDCP, Picture Mode, SUPER + Resolution, On-screen Digital Controls, 4-screen split, Flicker Safe, Reader Mode, SIX Axis Control, Joystick, Smart Energy Saving technology, Black Stabilizer, Response Time Control, Intelligent Auto, My Display Preset, Sleek Cut Design, Auto Power Off, Color Weakness Mode, Mega DFC |
Colour | Black |
Dimensions (WxDxH) | 51.01 cm x 18.68 cm x 39.53 cm - with stand |
Weight | 2.9 kg |
Connectivity | |
Interfaces | VGA , HDMI , DVI-D , Headphones |
Mechanical | |
Tilt Angle | -2/+15 |
Miscellaneous | |
Features | Key lock |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 24 Watt |
Power Consumption Sleep | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
OS Required | Windows 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 51.01 cm - depth: 18.68 cm - height: 39.53 cm - weight: 2.9 kg , Without stand - width: 51.01 cm - depth: 8.68 cm - height: 30.84 cm - weight: 2.5 kg |
