This display features Flicker Safe and Reader Mode to help maximize visual comfort by protecting your eyes from harmful blue light and greatly reducing the flicker level.
Protect Your Eyes and View in Comfort
Flicker Safe and Reader Mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero.
Preset Customized Options with just a Click
OnScreen Control and My Display Presets allow you to easily customize monitor settings with a few clicks of a mouse.
Customize Your Workspace for Multitasking
Screen Split divides the display for different tasks by resizing the windows on the screen. With PIP Mode you can work while watching a video in a window floating on the screen.
Offers Improved Color Vision to Color Weakness
Color revision algorithms are used to help those with color weakness who have difficulty distinguishing certain ranges of colors can view all the important content.
Product Description | LG 24M38H-B - LED monitor - Full HD (1080p) - 23.6" | Device Type | LED-backlit LCD monitor - 23.6" | Energy Class | Class A | Energy Consumption per Year | 31 kWh | Power Consumption (On mode) | 21 W | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Brightness | 200 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 5 ms | Input Connectors | HDMI, VGA | Voltage | AC 120/230 V | Dimensions (WxDxH) - with stand | 55.62 cm x 18.67 cm x 41.51 cm | Weight | 2.8 kg | Compliant Standards | Plug and Play, DDC/CI |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.6" |
Vertical Refresh Rate | 56 - 75 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
OSD Languages | Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean |
Features | Picture Mode, SUPER Energy Saving Technology, Auto Resolution, Dual Smart Solution, 4-screen split, Multilingual On Screen Display |
Dimensions (WxDxH) | 55.62 cm x 18.67 cm x 41.51 cm - with stand |
Weight | 2.8 kg |
Connectivity | |
Interfaces | VGA , HDMI , Headphones |
Mechanical | |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Power | |
Input Voltage | AC 120/230 V |
Power Consumption (Typical) | 19 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 55.62 cm - depth: 18.67 cm - height: 41.51 cm - weight: 2.8 kg , Without stand - width: 55.62 cm - depth: 5.68 cm - height: 34.4 cm - weight: 2.6 kg |
