2.1-channel audio takes your movies, TV shows and music beyond traditional stereo with the added bass kick of a dedicated subwoofer, imparting greater sonic power.
Stream music wirelessly from your smart phone for more versatile listening experience.
Want to listen to your favorite morning TV show while you get ready? Sync your Bluetooth -enabled television to your LG Music Flow speaker to enjoy TV audio in any room.
Product Description | LG LAS350B - sound bar system - wireless | Product Type | Sound bar system - 2.1-channel | System Components | Subwoofer, sound bar | Speaker Type | Active | Nominal Output Power (Total) | 120 Watt | Amplifier | Integrated | Interfaces | Bluetooth | Speaker System Details | 1 x sound bar 50 Watt , 1 x subwoofer 70 Watt | Speaker Details | Sound bar - stereo x 2 - 25 Watt - active , Speaker - subwoofer - 70 Watt - active | Colour | Black |
General | |
Enclosure Colour | Black |
Speaker System | |
Audio System Continuous Power (Total) | 120 Watt |
Speaker System Details | |
Speakers Included | 1 x sound bar - 50 Watt , 1 x subwoofer - 70 Watt |
Connections | |
Connector Type | Audio line-in , Digital audio input (optical) |
Power | |
Power Source | AC power adapter |
Dimensions & Weight | |
Dimensions (WxDxH) / Weight Details | Sound bar: 88 cm x 8.8 cm x 5.9 cm / 2.8 kg , Subwoofer: 15.6 cm x 28.1 cm x 30 cm / 5.7 kg |
