Designed for 24/7 continuous operation, the 47WS10 displays advertisements, information and broadcast video with Full HD brilliance. Its integrated RJ-45 LAN control enables individual management for multiple displays and eliminates the need for an IP card and an IP interface box. With landscape, portrait and 5 x 5 tile mode capabilities, the 47WS10 adapts to your signage needs.
Product Description | LG 47WS10 47" Class (46.9" viewable) LED-backlit LCD display - Full HD | Product Type | LED-backlit LCD flat panel display | Diagonal Class | 47" | Diagonal Size | 46.9" | Colour | Black | Resolution | 1920 x 1080 | Display Format | 1080p | Input Video Formats | 720p, 1080i, 1080p | Video Interface | Component, composite, HDMI | HDMI Ports Qty | 1 ports | PC Interface | VGA (HD-15) | HDCP Compatible | Yes | Technology | IPS | LCD Backlight Technology | LED backlight | Image Aspect Ratio | 16:9 | Sound Output Mode | Stereo | USB | Yes | Included Accessories | Remote control | Voltage | AC 120/230 V (50/60 Hz) | Power Consumption Operational | 120 Watt | Dimensions (WxDxH) - with stand | 110 cm x 29.7 cm x 72.1 cm | Weight | 18.9 kg | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 3-year warranty |
General | |
TV Tuner Presence | No |
Sensors | Temperature sensor |
Modes | Portrait mode, landscape mode |
Timer Functions | Sleep, wake |
Dimensions | With stand |
Width | 110 cm |
Depth | 29.7 cm |
Height | 72.1 cm |
Weight | 18.9 kg |
Enclosure Colour | Black |
Display | |
LCD Display Technology | IPS |
Coating | Anti-glare, hard |
Colour Depth | Up to 1.06 billion colours |
Image Contrast Ratio | 1300:1 |
Dynamic Contrast Ratio | 50000:1 |
Brightness | 450 cd/m² |
Colour Gamut | 72% |
Viewing Angle | 178 degrees |
Viewing Angle (Vertical) | 178 degrees |
Response Time | 12 ms |
V-Sync Rate at Max Res. | 148.5 Hz |
Max V-Sync Rate | 75 Hz |
Max H-Sync Rate | 83 kHz |
Display Menu Language | Hungarian, Indonesian, Ukrainian, English, German, French, Italian, Portuguese, Polish, Russian, Spanish, Dutch, Greek, Arabic, Japanese, Chinese, Korean, Kazakh |
Backlight Life | 30,000 hour(s) |
Colour Temperature Control | Yes (Warm/Medium/Cool) |
Picture Adjustment | Vivid/Standard/Cinema/Sports/Game |
Stands & Mounts | |
Stand | Optional |
Flat Panel Mount Interface | 400 x 400 mm |
Video Features | |
Media Player | |
USB Port | Yes |
USB Ports Qty | 1 |
Remote Control | |
Type | Remote control |
Audio System | |
Surround Mode | Yes |
Audio Controls | Sound mode |
Features | Clear Voice II technology |
Connections | |
Connector Type | Component video / AV / RGB input - rear , HDMI input - rear , Component video / AV / RGB output - rear , Audio line-in - rear , USB 2.0 - rear , LAN - rear , DVI-D input - rear , DVI-D output - rear , Serial input - rear , Serial output - rear , 2 x speakers output , DisplayPort |
Miscellaneous | |
Compliant Standards | FCC Class B certified, UL, TUV, VCCI, C-Tick, cUL, CB, KCC |
Sustainability Information | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 5.1 |
Power | |
Power Device | Power supply - internal |
Input Voltage | AC 120/230 V (50/60 Hz) |
Features | Smart energy saving |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 110 cm x 3.8 cm x 64.5 cm x 17.5 kg , Panel with stand - 110 cm x 29.7 cm x 72.1 cm x 18.9 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 118 cm |
Depth (Shipping) | 12.4 cm |
Height (Shipping) | 74.4 cm |
Weight (Shipping) | 21.5 kg |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% |
