High definition or HDTV offers greatly improved picture quality and sound than standard definition broadcasts. Finer detail, more colours and more vibrant images make High Definition the only choice when upgrading your TV.
Freeview - Get ready for the digital switch-over.
All LG TVs come with built-in Digital Freeview making sure you're ready for the digital switch-over. With LG TVs you'll have access to over 40 Freeview TV and radio channels, 8 day on-screen guide and access to digital interactive services.
*UK Only
Intelligent Sensor
ECO-FRIENDLY REVOLUTION - LG Intelligent Sensor technology automatically finds the optimal brightness, sharpness, colour and contrast picture settings to enhance the picture quality and reduce power consumption.
Product Description | LG 26LN450B 26" LED-backlit LCD TV - HD | Product Type | LED-backlit LCD TV | Diagonal Class | 26" | Resolution | 1366 x 768 | Display Format | 720p | Input Video Formats | 720p, 1080i, 1080p | Frame Rate & Enhancement Technology | 100 Hz Motion Clarity Index | 24p Technology | 24p Real Cinema | Video Interface | Component, composite, HDMI, SCART | HDMI Ports Qty | 1 ports | HDCP Compatible | Yes | LCD Backlight Technology | LED backlight | Speaker System | 2 speakers | Sound Effects | Virtual Surround Mode | Stereo Reception System | MTS | USB | Yes | Included Accessories | Remote control | Voltage | AC 120/230 V (50/60 Hz) | Energy Class | Class B | Power Consumption Operational | 38 Watt | Dimensions (WxDxH) - without stand | 62.1 cm x 7.29 cm x 38.6 cm | Weight | 4.2 kg |
General | |
TV Tuner Presence | Yes |
Sensors | Intelligent sensor |
Dimensions | Without stand |
Width | 62.1 cm |
Depth | 7.29 cm |
Height | 38.6 cm |
Weight | 4.2 kg |
Display | |
Widescreen Modes | Conventional 4:3, Zoom, 16:9, Full Wide, Just Scan, Original, Cinema Zoom |
Features | Eye Care, Enhanced Noise Reduction, Picture Wizard II, Triple XD Engine |
Stands & Mounts | |
Flat Panel Mount Interface | 100 x 100 mm |
TV Tuner | |
Conditional Access | Common Interface (CI) slot |
Secondary Audio Programme (SAP) | Yes |
Digital TV Tuner | |
HDTV Tuner | Yes |
Video Features | |
Electronic Programme Guide | Digital EPG |
Parental Channel Lock | Yes |
Media Player | |
Supported Video Formats | DivX HD |
Supported Audio Formats | MP3, PCM, AC3, AAC, E-AC3 |
Supported Pictures Formats | JPG |
USB Port | Yes |
USB Ports Qty | 1 |
Remote Control | |
Type | Remote control |
Audio System | |
Digital Audio Format | Dolby Digital output |
Surround Mode | Yes |
Audio Controls | Sound mode |
Output Power / Total | 10 Watt |
Features | Clear Voice II technology |
Speakers | 2 x speaker - 5 Watt |
Network & Internet Multimedia | |
Connect & Share | Mobile High-Definition Link (MHL) |
Connections | |
Connector Type | Audio line-in - side , HDMI - rear , USB 2.0 - side , Component video input - rear , SCART - rear , Composite video/audio input - rear , 2 x audio input - rear , Headphones - side |
Power | |
Power Device | Power supply |
Input Voltage | AC 120/230 V (50/60 Hz) |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 62.1 cm x 7.29 cm x 38.6 cm x 4.2 kg , Panel with stand - 62.1 cm x 16.21 cm x 43.1 cm x 4.5 kg |
