Take control of your workflow
The Lexar Professional Workflow line of products includes your choice of two four-bay reader and storage drive hubs, a selection of card readers, and two storage drives. Its innovative, modular design lets you create a custom setup, while its high-speed performance lets you offload and back up your work, faster. Pick and choose the right combination for your needs, and take control of your workflow.
Transfer and back up images and video from multiple memory cards at once
Mix and match any of the Professional Workflow readers and storage drives with your choice of hub to create your ideal setup. Whether you choose four card readers or a combination of card readers and storage drives, the solution lets you transfer and back up your images in a single click.
Customize your workflow with an innovative, modular design
Whether you're a pro photographer or videographer, an adventure seeker using a sports camcorder or aerial camera, or someone who needs a streamlined backup system, it's easy to create your custom workflow setup. The Professional Workflow line includes your choice of a USB 3.0 or Thunderbolt 2/USB 3.0 four-bay reader and storage drive hub, six readers, and two storage drives. Readers support SDHC/SDXC UHS-I and UHS-II, CompactFlash UDMA 7, XQD, CFast 2.0 (USB 3.0 or Thunderbolt), and microSDHC/microSDXC UHS-I formats, while the storage drives are offered in 256GB and 512GB capacities. Pick and choose the right combination for your needs. And for added versatility, you can remove the readers and storage drives from the hub for individual use on the go.
Simple setup and use
Simply plug the readers or storage drives of choice into the hub and start transferring and archiving files. It's that easy. Also, the Professional Workflow HR2 hub provides two Thunderbolt 2 ports and one USB 3.0 port, making it easy to daisy-chain with your existing setup. Having two Thunderbolt 2 ports also allows you to place the hub anywhere in your lineup of other Thunderbolt devices to create a unique, customizable setup. The hubs help you eliminate cable clutter and take control of your workflow.
Product Description | Lexar Professional Workflow SR2 - card reader - USB 3.0 | Product Type | Card reader - external | Supported Memory Cards | SDHC UHS-II Memory Card, SDXC UHS-II Memory Card | Host Interface | USB 3.0 | Features | Status indicator | Manufacturer Warranty | 2-year warranty |
General | |
Memory Card | |
Capacity | (max) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
