Lexar JumpDrive S70 - USB flash drive - 64 GB - USB 2.0
Key features
  • Convenient, reliable portable storage with retractable connector and convenient thumb slide
  • Reliably stores and transfers files, photos, videos, and more
  • Compatible with both PC and Mac systems
Product codes
chevron icon
chevron icon
Convenient, Secure Portable Storage
The Lexar® JumpDrive® S70 USB flash drive provides convenient, reliable portable storage for life on the go. This Hi-Speed USB drive with retractable connector and convenient thumb slide provides an excellent solution for safely storing, transferring, and sharing your valuable files, photos, videos, and more.
Stylish, Reliable Solution
Plug-and-Play Design with Great Features. The JumpDrive S70 USB flash drive has a simple plug-and-play design that allows you to quickly and easily store files, so wherever you go, your information goes with you. The drive also sports an LED activity light that blinks during data transfer, so you know when the job is done and data loss is averted.
Lexar Performance, Quality, Compatibility, and Reliability. All Lexar memory card, card reader, and USB flash drive product designs undergo extensive testing in the Lexar Quality Labs, facilities with more than 800 digital devices, to ensure performance, quality, compatibility, and reliability. This provides customers with a high level of confidence when using Lexar products to capture, manage, move, and store the memories that matter.
- Reliably stores and transfers files, photos, videos, and more
- Compatible with both PC and Mac® systems
- Two-year limited warranty
chevron icon
Product Description Lexar JumpDrive S70 - USB flash drive - 64 GB
Product Type USB flash drive
Storage Capacity 64 GB
Interface Type USB 2.0
Encryption 256-bit AES
Software Included Lexar Secure II
Manufacturer Warranty 2 years warranty
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
