Easily organize or archive your files with the Lexar® JumpDrive® V20 USB flash drive. It sports a slim design and comes in single or various two, three, or four multipack options in assorted colors. Each drive sports a protective label cover that makes it easy to slide in or swap out labels as needed, and includes write-on labels.
Forget where you stored your photos from last year’s trip? Wondering how to best archive all your tax files? Need a handy way to file class projects and assignments? So whether you prefer to sort by date, file type, or subject, JumpDrive V20 makes quick work of getting your files in order.
JumpDrive V20 is available in single and multipack options in assorted colors with write-on labels, providing a great color-coding system to help you reliably store and organize your drives and their contents. And with a protective label cover, you can easily slide in or swap out labels as needed.
Product Description | Lexar JumpDrive V20 - USB flash drive - 16 GB | Product Type | USB flash drive | Interface Type | USB 2.0 | Storage Capacity | 16 GB | Image Colour Disclaimer | The displayed product image may be a different colour | Manufacturer Warranty | 2-year warranty |
General | |
Memory | |
Features | LED access indicator |
Miscellaneous | |
Included Accessories | Labels |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
