The ultimate entertainment tablet – with a brilliant QHD screen to binge-watch your favourite TV programmes and a rotating projector plus powerful speakers to share the fun with anyone.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Lenovo Yoga Tablet 3 Pro ZA0F - tablet - Android 5.1 - 32 GB - 10.1" | Product Type | Tablet | Operating System | Android 5.1 | Display | 10.1" IPS - 2560 x 1600 (299 ppi) - Multi-Touch | Processor | Intel Atom x5 Z8500 (Quad-Core) - 64-bit | Processor Clock Speed | 2.24 GHz | Storage | 32 GB eMMC | RAM | 2 GB | Supported Flash Memory Cards | microSD | Wireless Connectivity | 802.11a/b/g/n, Bluetooth 4.0 | Rear Camera | 13 Megapixel | Front Camera | 5 Megapixel | Navigation System | GPS/GLONASS | Battery Run Time | Up to 18 hours | Dimensions (WxDxH) | 17.9 cm x 0.468 cm x 24.7 cm | Weight | 665 g | Colour | Black | Localisation | English / Germany | Manufacturer Selling Program | TopSeller | Manufacturer Warranty | 1-year warranty |
General | |
Display | |
Type | 10.1" IPS |
Resolution | 2560 x 1600 (299 ppi) |
Colour Gamut | 70% |
Touchscreen | Multi-Touch |
Image Aspect Ratio | 16:10 |
Features | 10-point multi-touch |
Processor | |
Processor | Intel Atom x5 Z8500 |
Number of Cores | Quad-Core |
64-bit Computing | Yes |
Memory | |
RAM | 2 GB - LPDDR3 SDRAM |
Max Supported Capacity | 128 GB |
Communications | |
Rear Camera | |
Sensor Resolution | 13 Megapixel |
Front Camera | |
Sensor Resolution | 5 Megapixel |
Navigation System | |
Receiver | GPS/GLONASS |
Multimedia | |
Supported Digital Audio Standards | Dolby Atmos |
Audio | Four speakers |
Expansion and Connectivity | |
Interfaces | 1 x Micro-USB , 1 x headset mini jack (3.5mm) |
Battery | |
Capacity | 10200 mAh |
Standby Time | 1176 h |
Miscellaneous | |
Colour | Black |
Case Material | Plastic, metal |
Sensors | Ambient light sensor, digital compass, G-sensor |
Features | Built-in projector |
Vibrating Alert | Yes |
Included Accessories | Power adapter |
Cables Included | Micro-USB cable |
Dimensions & Weight | |
Width | 17.9 cm |
Depth | 0.468 cm |
Height | 24.7 cm |
Weight | 665 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - pick-up and return |
