Four ways to use your tablet
Yoga Tab 3 10's innovative design places a battery cylinder and kickstand on the side of the device, shifting the center of gravity and opening up multiple ways to use it: Hold, Tilt, Stand, and Hang. That means there are four different ways to enjoy media content, games, and more.
Immersive multimedia
Yoga Tab 3 10 boasts a vibrant HD display and dual, front-facing speakers, enhanced with Dolby Atmos 3D surround sound.
Rotatable camera
Yoga Tab 3 10's camera rotates 180 degrees. Better picture quality at any angle, better Skype chats, better selfies. All in all, a more creative approach to tablet photography.
Epic battery life
With a battery life that hits long hours on a single charge, the Yoga Tab 3 10 will run all day - and into the night - without plugging in.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Lenovo Yoga Tablet 3 850F ZA09 - tablet - Android 5.1 - 16 GB - 8" | Product Type | Tablet | Operating System | Android 5.1 | Display | 8" IPS TFT - 1280 x 800 - Multi-Touch | Processor | Qualcomm Snapdragon APQ8009 (Quad-Core) | Processor Clock Speed | 1.3 GHz | Storage | 16 GB eMMC | RAM | 2 GB | Supported Flash Memory Cards | microSD | Wireless Connectivity | 802.11b/g/n, Bluetooth 4.0 | Rear Camera | 8 Megapixel | Navigation System | GPS | Battery Run Time | Up to 20 hours | Dimensions (WxDxH) | 14.6 cm x 0.7 cm x 21 cm | Weight | 466 g | Colour | Slate black | Manufacturer Selling Program | TopSeller | Manufacturer Warranty | 1-year warranty |
General | |
Display | |
Type | 8" IPS TFT |
Resolution | 1280 x 800 |
Touchscreen | Multi-Touch |
Image Aspect Ratio | 16:10 |
Image Brightness | 400 cd/m² |
Features | 10-point multi-touch |
Processor | |
Processor | Qualcomm Snapdragon APQ8009 |
Number of Cores | Quad-Core |
Memory | |
RAM | 2 GB - LPDDR2 SDRAM |
Max Supported Capacity | 128 GB |
Communications | |
Rear Camera | |
Sensor Resolution | 8 Megapixel |
Navigation System | |
Receiver | GPS |
Multimedia | |
Graphics | Qualcomm ADRENO 304 |
Supported Digital Audio Standards | Dolby Atmos |
Audio | Microphone, stereo speakers |
Expansion and Connectivity | |
Expansion Slots | 1 x microSD |
Interfaces | 1 x headset , 1 x Micro-USB |
Battery | |
Technology | Lithium Ion |
Capacity | 6200 mAh |
Miscellaneous | |
Case Material | Plastic |
Sensors | Ambient light sensor, digital compass, G-sensor, hall sensor |
Vibrating Alert | Yes |
Included Accessories | Power adapter |
Compliant Standards | RoHS |
Dimensions & Weight | |
Width | 14.6 cm |
Depth | 0.7 cm |
Height | 21 cm |
Weight | 466 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - pick-up and return |
