Stay unplugged longer with ThinkPad batteries. Providing up to one-third more capacity than the standard system battery. This high-capacity battery has an extended area on the back edge and fits in the standard ThinkPad system battery slot. Its compatible design allows it to be in a system connected to the ThinkPad Advanced Dock, Advanced Mini-Dock, and Essential Port Replicator. Battery life and recharge times vary based on many factors including screen brightness, applications, features, power management, battery conditioning, and other customer preferences. (For battery life, go to lenovo.com/alldaycomputing)
Compatible with T/R/W500, T60/61 14S/15W, SL400/500.
Product Description | Lenovo - laptop battery - Li-Ion - 7800 mAh | Device Type | Laptop battery | Weight | 475 g | Battery | Lithium Ion 9-cell - 7800 mAh | Dimensions (WxDxH) | 22.7 cm x 7.9 cm x 2.1 cm | Manufacturer Warranty | 1-year warranty | Designed For | T60 2007; T60 1951; T61 6466; T500 2055; R61 7732, 7733, 7734, 7735; R60 9460, 9461, 9462, 9464; SL500 2746; T500 2243; T61 6460; R500 2716; T500 2082; R500 2714; R60 9455, 9456, 9457, 9459; R61 8918; R60 9456; R500 2713; R60 9444, 9445, 9446; R60e 0656, 0657, 0658, 0659; R500 2718; R500 2717 |
General | |
Battery | |
Technology | 9-cell Lithium Ion |
Voltage Provided | 10.8 V |
Capacity | 7800 mAh |
Miscellaneous | |
Compliant Standards | C-Tick, cUL, UL 1950, ACA |
Manufacturer Warranty | |
Service & Support | Limited warranty - replacement - 1 year |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 8 - 95% |
Dimensions & Weight | |
Width | 22.7 cm |
Depth | 7.9 cm |
Height | 2.1 cm |
Weight | 475 g |
Compatibility Information | |
Designed For | Lenovo ThinkPad R500 2713, 2714, 2716, 2717, 2718, 2719, 2720, 2731, 2732, 2733, 2735 , Lenovo ThinkPad R60 9444, 9445, 9446, 9447, 9455, 9456, 9457, 9458, 9459, 9460, 9461, 9462, 9463, 9464 , Lenovo ThinkPad R60e 0656, 0657, 0658, 0659 , Lenovo ThinkPad R61 7642, 7643, 7644, 7645, 7646, 7647, 7648, 8914, 8918, 8919, 8920, 8927, 8928, 8929, 8930, 8932, 8933, 8934, 8935, 8936, 8937, 8942, 8943, 8944, 8947 , Lenovo ThinkPad R61e 7649, 7650, 7657 , Lenovo ThinkPad R61i 7650, 8918, 8932, 8943 , Lenovo ThinkPad SL300 2738 , Lenovo ThinkPad SL400 2743 , Lenovo ThinkPad SL400c 4413 , Lenovo ThinkPad SL500 2746 , Lenovo ThinkPad SL500c 4414 , Lenovo ThinkPad T500 2055, 2056, 2081, 2082, 2087, 2088, 2089, 2241, 2242, 2243, 2247 , Lenovo ThinkPad T60 1951, 1952, 1953, 1954, 1955, 1956, 2007, 2008, 2009, 2613, 2623, 2637, 6369, 6370, 6371, 6372, 6373, 6374, 8741, 8742, 8743, 8744, 8745, 8746 , Lenovo ThinkPad T60p 2007, 2008, 2009, 2613, 2623, 8741, 8742, 8743, 8744, 8745, 8746 , Lenovo ThinkPad T61 6457, 6458, 6459, 6460, 6461, 6462, 6463, 6464, 6465, 6466, 6467, 6468, 6470, 6471, 8889, 8890, 8891, 8892, 8893, 8894, 8895, 8896, 8897, 8898, 8899, 8900, 8938, 8939 , Lenovo ThinkPad T61p 6457, 6458, 6459, 6460, 6461, 8889, 8890, 8891 , Lenovo ThinkPad T61u 6457, 6463 , Lenovo ThinkPad W500 2055, 4058, 4061, 4062, 4063, 4064, 4065 , Lenovo ThinkPad Z61e 0672, 0673 , Lenovo ThinkPad Z61m 0674, 9450, 9451, 9452, 9453 |
