ThinkVision LT1913p 19-inch Square In-plane Switching LED Backlit LCD Monitor.
The Lenovo ThinkVision monitor LT1913p is a commercial monitor with premium product features which suits users using traditional legendary square display formats best. With built-in VGA + DVI interfaces, it offers users outstanding HD picture quality. It displays an absolutely clear picture quality with its In-plane Switching panel, which is soothing for the human eye after long viewing in office working environments and has extensive wide-angle views. It contains full ergonomic features with its full-function stand, offering tilt, lift, pivot and swivel functions. The LT1913p monitor coordinates with any Lenovo ThinkCentre systems and matches the Lenovo design thanks to its black finish. It delivers the best value on investment for large enterprises. It is environmentally conscious, meeting the latest green standards including Energy Star 6.0 Certified, TUV Green Mark, EPEAT Gold Certified, TCO Display 6.0, TCO Certified Edge 1.1, UL Environment Gold, CEL 1, RoHs and 85% PCC plastic resins. To save space, this monitor is also designed to support ThinkCentre's Tiny PC with the Clamp Bracket.
Product Description | Lenovo ThinkVision LT1913p - LED monitor - 19" | Device Type | LED-backlit LCD monitor - 19" | Energy Class | Class E | Power Consumption (On mode) | 12.6 W | Panel Type | IPS | Aspect Ratio | 5:4 | Native Resolution | 1280 x 1024 at 76 Hz | Pixel Pitch | 0.0976 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 7 ms | Colour Support | 16.7 million colours | Colour Gamut | 72% | Input Connectors | DVI-D, VGA | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Business black | Dimensions (WxDxH) | 41.1 cm x 22.19 cm x 37.83 cm | Weight | 4.55 kg | Localisation | English / United Kingdom | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | FCC Class B certified, TUV, VCCI, BSMI, GOST, GS, NEMKO, NOM, SASO, TUV S, VESA EDID, CCC, IC, PSB, RoHS, ISO 9241-307, KCC, WEEE, Green Mark, JEITA, cTUVus, REACH, E-Standby, KC, Kvalitet, CECP, DDC-2B/CI, EPA 6.0, CEL Grade 1, China RoHS, IEC60950/EN60950, VOC, CU | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 19" |
Panel Type | IPS |
Pixel Per Inch | 86.8 |
Vertical Refresh Rate | 60 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
OSD Languages | English, German, French, Italian, Russian, Spanish, Japanese, Chinese |
Features | HDCP |
Weight | 4.55 kg |
Connectivity | |
Interfaces | DVI-D (HDCP) , VGA |
Mechanical | |
Tilt Angle | -5/+30 |
Swivel Angle | 90 |
Rotation Angle | 90 |
Height Adjustment | 110 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable - 1.8 m , 1 x DVI cable - 1.8 m |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 12.6 kWh/1000h |
Power Consumption (Typical) | 24 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - replacement - 3 years - carry-in |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% |
