ThinkVision E2054 19.5-inch LED Backlit LCD Monitor. The Lenovo ThinkVision E2054 monitor provides essential functionality for commercial users who balance between performance and value. With wide-viewing angle IPS panel, images are clear in 178°/178° angle. It is also designed to be compact and space-saving which supports Thinkcenter Tiny PC via VESA bracket mounting.
Product Description | Lenovo ThinkVision E2054 - LED monitor - 19.5" | Device Type | LED-backlit LCD monitor - 19.5" | Energy Class | Class D | Power Consumption (On mode) | 9.9 W | Panel Type | IPS | Aspect Ratio | 16:10 | Native Resolution | 1440 x 900 | Pixel Pitch | 0.097 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 7 ms (grey-to-grey) | Colour Gamut | 72% | Input Connectors | VGA | Display Position Adjustments | Tilt | Colour | Raven black | Dimensions (WxDxH) | 45.6 cm x 18.83 cm x 37.2 cm | Weight | 2.18 kg | Localisation | English / United Kingdom | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | FCC Class B certified, TUV, DDC-2B, VESA DPMS, DDC/CI, RoHS, ISO 9241-307, WEEE, Green Mark, CEL Grade 1, China RoHS, EDID compatible | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 19.5" |
Panel Type | IPS |
Pixel Per Inch | 87 |
Horizontal Viewing Angle | +89 / -89 |
Vertical Viewing Angle | +89 / -89 |
Backlight Technology | LED backlight |
Controls & Adjustments | Brightness |
Features | HDCP, Mercury free |
Weight | 2.18 kg |
Connectivity | |
Interfaces | VGA (HD-15) |
Mechanical | |
Tilt Angle | -5/+22 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Included Accessories | Stand |
Cables Included | 1 x VGA cable - VGA to VGA - 1.8 m |
Power | |
Power Consumption SDR (On mode) | 9.9 kWh/1000h |
Power Consumption (Typical) | 16 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , Limited warranty - backlight - 3 years |
