With powerful processing and long battery life, the ThinkPad T470 is designed to enhance your productivity, anywhere. Easy to use, deploy, and service, this robust laptop has a host of cutting-edge technology, including fast storage, and secure fingerprint reading.
Product Description | Lenovo ThinkPad T470 - 14" - Intel Core i5 - 7200U - 8 GB RAM - 256 GB SSD - UK | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache | Memory | 8 GB DDR4 (1 x 8 GB) | Storage | 256 GB SSD - TCG Opal Encryption 2, NVMe | Display | 14" LED backlight 1920 x 1080 / Full HD | Graphics | Intel HD Graphics 620 | Input Device | TrackPoint, UltraNav | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet | Battery | 3-cell - up to 13.9 hours | Dockable | Yes | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader | Colour | Black | Dimensions (WxDxH) | 33.66 cm x 23.25 cm x 1.995 cm | Weight | 1.65 kg | Localisation | Language: English / region: United Kingdom | Manufacturer Selling Program | TopSeller | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7200U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Integrated memory controller |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 256 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe) |
Display | |
Type | 14" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 250 cd/m² |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes - 720p |
Sound | Stereo speakers, dual array microphone |
Codec | Realtek ALC3268 |
Compliant Standards | High Definition Audio |
Input | |
Type | Keyboard, TrackPoint, UltraNav |
Keyboard Layout | UK |
Features | Spill-resistant, multi-touch touchpad, buttonless touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 - M.2 Card |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-V |
Wireless Broadband (WWAN) | |
Generation | WWAN upgradable |
Battery | |
Technology | 3-cell Lithium Ion |
Installed Qty | 2 |
Capacity | 24 Wh |
Run Time | Up to 13.9 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt |
Connections & Expansion | |
Interfaces Details | 2 x USB 3.1 Gen 1/USB 3.0 , USB 3.1 Gen 1/USB 3.0 (Always On) , USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery 2.0) , HDMI , LAN , Dock , Headphone/microphone combo jack |
Memory Card Reader | Yes (SDXC UHS Card) |
Software | |
Software Included | Lenovo Companion, Lenovo Settings |
Miscellaneous | |
Colour | Black |
Case Material | Glass-fibre reinforced plastic, polyphenylene sulfide |
Dockable | Yes |
Features | Administrator password, hard drive password, power-on password, MIL-STD-810G tested |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | RoHS |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.65 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year |
