Designed for high-end professionals in industries ranging from media and entertainment to oil and gas, the Lenovo ThinkPad P70 introduces a 17-inch mobile workstation to the ThinkPad family. The new offering comes packed with the most memory and storage ever found in a mobile workstation. The ThinkPad P70 is loaded with up to 64GB of DDR4 ECC memory and the ability to handle up to four storage devices and up to a terabyte of SSD storage, utilizing the latest PCIe technology for speeds up to five times faster than current SATA technology. Additionally, the ThinkPad P70 comes with two Intel Thunderbolt 3 ports for ultra-fast connectivity and a 4K UHD display or optional FHD touch.
Product Description | Lenovo ThinkPad P70 - 17.3" - Intel Core i7 - 6820HQ - vPro - 16 GB RAM - 512 GB SSD - UK | Product Type | Mobile workstation | Operating System | Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence | Platform Technology | Intel vPro Platform | Processor | Intel Core i7 (6th Gen) - 6820HQ / 2.7 GHz, up to 3.6 GHz / 8 MB Cache | Memory | 16 GB DDR4 (2 x 8 GB) | Storage | 512 GB SSD | Optical Drive | DVD-Writer | Display | 17.3" LED backlight 3840 x 2160 / Ultra HD 4K | Graphics | NVIDIA Quadro M3000M | Video Memory | 4 GB | Input Device | Keyboard, touchpad | Keyboard | UK | Keyboard Backlight | Yes | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet | Battery | 8-cell | Features | X-Rite Pantone colour sensor | Dockable | Yes | Security | Fingerprint reader, smart card reader | Dimensions (WxDxH) | 41.6 cm x 27.55 cm x 3.42 cm | Weight | 3.4 kg | Localisation | Language: English / region: United Kingdom | Manufacturer Selling Program | TopSeller | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | Limited warranty - 3 years - on-site |
General | |
Operating System | Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence |
Processor / Chipset | |
CPU | Intel Core i7 (6th Gen) 6820HQ / 2.7 GHz |
Max Turbo Speed | 3.6 GHz |
Number of Cores | Quad-Core |
Cache | 8 MB |
64-bit Computing | Yes |
Chipset | Mobile Intel CM236 Express |
Features | Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 16 GB (2 x 8 GB) |
Max RAM Supported | 64 GB |
Technology | DDR4 SDRAM - non-ECC |
Speed | 2133 MHz / PC4-17000 |
Rated Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 4 |
Empty Slots | 2 |
Storage | |
Main Storage | 512 GB SSD SATA 6Gb/s |
Display | |
Type | 17.3" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 3840 x 2160 (Ultra HD 4K) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 300 cd/m² |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | NVIDIA Quadro M3000M |
Camera | Yes |
Sound | Dual array microphone |
Compliant Standards | Dolby Home Theater v4 |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Wireless Controller | Intel Dual Band Wireless-AC 8260 |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | 8-cell |
Capacity | 96 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Connections & Expansion | |
Slots | 1 x ExpressCard/34 (1 free) |
Interfaces Details | 4 x USB 3.0 , HDMI , Mini DisplayPort , 2 x Thunderbolt 3 , Dock , LAN , Headphone/microphone combo jack |
Memory Card Reader | 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card) |
Miscellaneous | |
Integrated Options | X-Rite Pantone colour sensor |
Dockable | Yes |
Features | Intel Active Management Technology (iAMT), 1 USB 3.0 (Always On) |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | RoHS, GREENGUARD |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 3.4 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - on-site |
