Powerful and durable, the ThinkPad E570 is light enough to go wherever your business takes you. Designed to enhance productivity, the 15.6" laptop has smooth, fast processing, a hi-res display, and an ergonomic keyboard as standard. It can also be configured to best meet your business needs for PC storage, memory, graphics - and budget.
Product Description | Lenovo ThinkPad E570 - 15.6" - Intel Core i5 - 7200U - 8 GB RAM - 256 GB SSD - UK | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache | Memory | 8 GB DDR4 (1 x 8 GB) | Storage | 256 GB SSD - TCG Opal Encryption 2, NVMe | Optical Drive | DVD-Writer | Display | 15.6" LED backlight 1920 x 1080 / Full HD | Graphics | Intel HD Graphics 620 | Input Device | TrackPoint, UltraNav | Keyboard | UK | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet | Battery | 4-cell - up to 7 hours | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader | Colour | Black (LCD cover), silver (top cover) | Dimensions (WxDxH) | 37.9 cm x 26.1 cm x 2.54 cm | Weight | 2.3 kg | Localisation | Language: English / region: United Kingdom | Manufacturer Selling Program | TopSeller | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | Limited warranty - 1 year - pick-up and return |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7200U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Integrated memory controller |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 256 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe) |
Optical Drive | DVD-Writer removable |
Display | |
Type | 15.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 250 cd/m² |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes - 720p |
Sound | Stereo speakers, dual array microphone |
Codec | CX11852 |
Compliant Standards | High Definition Audio, Dolby Audio Premium |
Input | |
Type | Keyboard, TrackPoint, UltraNav |
Keyboard Layout | UK |
Features | Spill-resistant, multi-touch touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Wireless Controller | Qualcomm 435-AC - M.2 Card |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Realtek R8111GUS |
Battery | |
Technology | 4-cell Lithium Ion |
Capacity | 41 Wh |
Run Time | Up to 7 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt |
Connections & Expansion | |
Interfaces Details | 2 x USB 3.0 , USB 2.0 (Always On) , HDMI , VGA , LAN , Headphone/microphone combo jack , USB-C |
Memory Card Reader | 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card) |
Software | |
Software Included | Lenovo Companion, Lenovo Settings, McAfee LiveSafe (30 days trial) |
Miscellaneous | |
Case Material | Polycarbonate ABS |
Features | Administrator password, hard drive password, power-on password |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | RoHS |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 2.3 kg |
Sustainability Information | |
TCO Certified | - |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - pick-up and return |
