This portable, ThinkPad 65 W slim adapter ensures you need never be without access to power. The ThinkPad 65 W AC adapter is compatible with post-2013 Lenovo notebooks with a rectangular "slim-tip" common power plug. The compact design performs to the same specifications as the standard AC adapters supplied with the notebooks. Each one is energy efficient with Energy Star V (ES 2.0) technology and is protected by a one-year limited warranty with Lenovo.
Product Description | Lenovo ThinkPad 65W Slim AC Adapter (Slim Tip) - power adapter - 65 Watt | Device Type | Power adapter - external | Weight | 235 g | Localisation | Saudi Arabia, Hong Kong, Myanmar, Malaysia, Singapore, Malta, United Kingdom | Power Capacity | 65 Watt | Dimensions (WxDxH) | 6.5 cm x 10.5 cm x 1.7 cm | Manufacturer Warranty | 1-year warranty |
General | |
Power Device | |
Input Voltage Range | AC 100 - 240 V |
Frequency Required | 50/60 Hz |
Miscellaneous | |
Compliant Standards | UL, C-Tick, BSMI, GOST, cUL, GS, NEMKO, NOM, CB, CCC, EMC, PSB, FCC, PSE Mark, ICES, MEPS, KC, CECP, EMI |
Manufacturer Warranty | |
Service & Support | Limited warranty - replacement - 1 year |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 8 - 80% (non-condensing) |
Dimensions & Weight | |
Width | 6.5 cm |
Depth | 10.5 cm |
Height | 1.7 cm |
Weight | 235 g |
