Digital learning engages students, streamlines classroom management, and improves academic outcomes but it's a rough business. Lenovo ThinkPad 11e is built to withstand the drops and bumps that are bound to come with student use without sacrificing performance.
Product Description | Lenovo ThinkPad 11e (3rd Gen) - 11.6" - Intel Celeron - N3150 - 4 GB RAM - 192 GB SSD - UK | Product Type | Notebook | Operating System | Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence | Processor | Intel Celeron N3150 / 1.6 GHz, up to 2.08 GHz / 2 MB Cache | Memory | 4 GB DDR3L (1 x 4 GB) | Storage | 192 GB SSD | Display | 11.6" LED backlight 1366 x 768 / HD | Graphics | Intel HD Graphics | Keyboard | UK | Integrated Webcam | Yes | Networking | Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet | Battery | 3-cell - up to 11.53 hours | Security | Trusted Platform Module (TPM 1.2) Security Chip | Colour | Graphite black | Dimensions (WxDxH) | 30 cm x 21 cm x 2.23 cm | Weight | 1.5 kg | Localisation | Language: English / region: United Kingdom | Manufacturer Selling Program | TopSeller | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | Limited warranty - 1 year - pick-up and return |
General | |
Operating System | Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence |
Processor / Chipset | |
CPU | Intel Celeron N3150 / 1.6 GHz |
Max Turbo Speed | 2.08 GHz |
Number of Cores | Quad-Core |
Cache | 2 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, integrated memory controller, Intel Burst Technology |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 8 GB |
Technology | DDR3L SDRAM |
Speed | 1600 MHz / PC3L-12800 |
Rated Speed | 1600 MHz |
Form Factor | SO-DIMM 204-pin |
Slots Qty | 1 |
Empty Slots | 0 |
Storage | |
Main Storage | 192 GB SSD M.2 SATA 6Gb/s |
Display | |
Type | 11.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 220 cd/m² |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics |
Camera | Yes - 720p |
Sound | Stereo speakers, microphone |
Codec | Realtek ALC3245 |
Compliant Standards | High Definition Audio |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Volume control, multi-touch touchpad, buttonless touchpad |
Communications | |
Wireless | Bluetooth 4.0, 802.11a/b/g/n/ac |
Wireless Controller | Intel Dual Band Wireless-AC 7265 - M.2 Card |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Realtek RTL8111GUS-CG |
Battery | |
Technology | 3-cell lithium polymer |
Capacity | 42 Wh |
Run Time | Up to 11.53 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt |
Connections & Expansion | |
Interfaces Details | 2 x USB 3.0 , HDMI , LAN , Headphone/microphone combo jack |
Memory Card Reader | 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card) |
Software | |
Software Included | ThinkVantage Rescue and Recovery, Adobe Reader, ThinkVantage System Update, ThinkVantage Product Recovery, Lenovo Solution Center, McAfee LiveSafe (30 days trial) |
Miscellaneous | |
Case Material | Polycarbonate, glass-fibre reinforced plastic |
Features | Administrator password, hard drive password, power-on password, MIL-STD-810G tested |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | RoHS |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.5 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - pick-up and return |
