The Edge 72 entry-level business desktop PC delivers the fundamentals; great application performance and reliability, while legendary Lenovo service will keep you online and your customers happy.
Product Description | Lenovo ThinkCentre Edge 72 - SFF - Core i5 3470S 2.9 GHz - 4 GB - HDD 500 GB | Type | Personal computer - small form factor - administrator password, hard drive password, power-on password, boot without keyboard or mouse, USB port control, boot sequence control | Localisation | Language: English / region: United Kingdom | Processor | Intel Core i5 (3rd Gen) 3470S / 2.9 GHz (3.6 GHz) (Quad-Core) | Processor Socket | LGA1155 Socket | Processor Main Features | Intel Extended Memory 64 Technology, Intel Virtualization Technology, Intel Turbo Boost Technology 2 | Cache Memory | 6 MB | Cache Per Processor | 6 MB | RAM | 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - PC3-12800 | Storage Controller | SATA (SATA 3Gb/s) | Hard Drive | HDD 500 GB - SATA 3Gb/s - 7200 rpm | Optical Storage | DVD SuperMulti | Graphics Controller | Intel HD Graphics 2500 | Audio Output | Stereo - integrated | Networking | GigE | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 8 Pro 64-bit Edition | Microsoft Office Preloaded | Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC. | Colour | Glossy black | Dimensions (WxDxH) | 33.6 cm x 38.2 cm x 10.1 cm | Weight | 6 kg | Manufacturer Selling Program | TopSeller | Manufacturer Warranty | Limited warranty - 1 year - on-site - response time: next business day |
General | |
Type | Personal computer |
Product Form Factor | Small form factor |
Built-in Devices | Speaker |
Processor / Chipset | |
CPU | Intel Core i5 (3rd Gen) 3470S |
Clock Speed | 2.9 GHz |
Max Turbo Speed | 3.6 GHz |
Number of Cores | Quad-Core |
64-bit Computing | Yes |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Socket | LGA1155 Socket |
Chipset Type | Intel H61 Express |
Cache Memory | |
Installed Size | 6 MB |
RAM | |
Installed Size | 4 GB / 16 GB (max) |
Technology | DDR3 SDRAM |
Effective Memory Speed | 1600 MHz |
Rated Memory Speed | 1600 MHz |
Memory Specification Compliance | PC3-12800 |
Form Factor | DIMM 240-pin |
Slots | 2 (Total) / 1 (empty) |
Features | Unbuffered, dual channel memory architecture |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | HDD |
Capacity | 1 x 500 GB |
Interface Type | SATA 3Gb/s |
Spindle Speed | 7200 rpm |
Storage Controller | |
Type | 1 x SATA - integrated |
Controller Interface Type | SATA 3Gb/s |
Channel Qty | 3 |
Optical Storage | |
Type | DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Type | Integrated |
Graphics Processor | Intel HD Graphics 2500 |
Video Interfaces | VGA, DVI |
Max Monitors Supported | 2 |
Audio Output | |
Type | Integrated |
Sound Output Mode | Stereo |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Keyboard Name | Lenovo Slim USB Keyboard |
Interface | USB |
Mouse | |
Technology | Optical |
Interface | USB |
Features | Scroll |
Networking | |
Type | Integrated |
Ethernet Controller | Realtek RTL8111E |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Features | Wake on LAN (WoL) |
Expansion / Connectivity | |
Bays | 1 (total) / 0 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x internal 3.5" x 1/3H , 1 (total) / 0 (free) x external 1.5" |
Slots | 2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile , 2 (total) / 2 (free) x PCIe 2.0 x1 - low-profile |
Interfaces | 6 x USB 2.0 (2 front, 4 rear) , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DVI-D , 1 x audio line-in , 1 x audio line-out , 1 x parallel , 1 x serial |
Miscellaneous | |
Features | Administrator password, hard drive password, power-on password, boot without keyboard or mouse, USB port control, boot sequence control |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately), padlock loop |
Compliant Standards | RoHS |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 180 Watt |
Operating System / Software | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - on-site - response time: next business day |
Dimensions & Weight | |
Width | 33.6 cm |
Depth | 38.2 cm |
Height | 10.1 cm |
Weight | 6 kg |
