Feature-rich and feather-light, this Ultrabook boasts high processing power; MILSPEC-tested durability; amazing audiovisuals; effortless manageability; and all-day battery life. The well-connected business person likes to travel light, and T460s lets you do just that.
Product Description | Lenovo ThinkPad T460s - 14" - Intel Core i5 - 6200U - 8 GB RAM - 256 GB SSD - 4G LTE-A - UK | Product Type | Ultrabook | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache | Memory | 8 GB DDR4 (1 x 4 GB + 4 GB (soldered)) | Storage | 256 GB SSD - TCG Opal Encryption 2 | Display | 14" LED backlight 2560 x 1440 / WQHD | Graphics | Intel HD Graphics 520 | Input Device | TrackPoint, UltraNav | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet | Wireless Broadband (WWAN) | 4G LTE Advanced | Service Provider | Lenovo | Battery | 3-cell | Dockable | Yes | Security | Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader | Dimensions (WxDxH) | 33.1 cm x 22.68 cm x 1.88 cm | Weight | 1.36 kg | Localisation | Language: English / region: United Kingdom | Manufacturer Selling Program | TopSeller | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (6th Gen) 6200U / 2.3 GHz |
Max Turbo Speed | 2.8 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 8 GB (1 x 4 GB + 4 GB (soldered)) |
Max RAM Supported | 20 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz / PC4-17000 |
Rated Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 1 |
Empty Slots | 0 |
Storage | |
Main Storage | 256 GB SSD M.2 SATA 6Gb/s - TCG Opal Encryption 2 |
Display | |
Type | 14" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 2560 x 1440 (WQHD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 300 cd/m² |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 520 |
Camera | Yes - 720p |
Sound | Stereo speakers, two microphones |
Codec | Realtek ALC3245 |
Compliant Standards | High Definition Audio |
Input | |
Type | Keyboard, TrackPoint, UltraNav |
Keyboard Layout | UK |
Features | Spill-resistant, multi-touch touchpad, buttonless touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Wireless Controller | Intel Dual Band Wireless-AC 8260 - M.2 Card |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-V |
Wireless Broadband (WWAN) | |
Generation | 4G |
Technology | UMTS, HSPA, HSPA+, DC-HSPA+, LTE Advanced |
Controller | Sierra Wireless EM7455 - M.2 Card |
Navigation | |
Receiver | GPS |
Battery | |
Technology | 3-cell lithium polymer |
Installed Qty | 1 |
Max Supported Qty | 2 |
Capacity | 23 Wh |
Run Time With Included Additional Battery | Up to 10.5 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt |
Connections & Expansion | |
Slots | 1 x Micro-SIM card (1 free) |
Interfaces Details | 2 x USB 3.0 , USB 3.0 (Always On) , HDMI , Mini DisplayPort , LAN , Dock , Headphone/microphone combo jack |
Memory Card Reader | 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card) |
Software | |
Software Included | Lenovo Solution Center, Lenovo Companion, Lenovo Settings, McAfee LiveSafe (30 days trial) |
Miscellaneous | |
Case Material | Magnesium alloy, carbon fibre reinforced plastic |
Dockable | Yes |
Features | Administrator password, hard drive password, power-on password, ThinkEngine, MIL-STD-810G tested |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter, 3-cell Li-Ion 26Wh battery, Lenovo Connect SIM card |
Compliant Standards | RoHS, GREENGUARD |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.36 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year |
