The world's most Powerful core i tablet w/ external GFX.
Product Description | Lenovo IdeaPad Miix 720-12IKB - 12" - Intel Core i5 - 7200U - 8 GB RAM - 256 GB SSD - UK | Product Type | Tablet - with detachable keyboard | Operating System | Win 10 Pro 64-bit - English | Processor | Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache | Memory | 8 GB DDR4 (provided memory is soldered) | Storage | 256 GB SSD | Display | 12" LED backlight touchscreen 2880 x 1920 / QHD+ | Graphics | Intel HD Graphics 620 | Input Device | Digitizer, digital pen, detachable keyboard | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1 | Battery | 4-cell - up to 8 hours | Colour | Black | Dimensions (WxDxH) - tablet | 29.2 cm x 21 cm x 0.89 cm | Weight | 780 g | Localisation | Language: English / region: United Kingdom | Environmental Standards | - EPEAT Climate+ | Manufacturer Warranty | Limited warranty - 1 year - pick-up and return |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7200U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Integrated memory controller |
Memory | |
RAM | 8 GB (provided memory is soldered) |
Technology | DDR4 SDRAM |
Speed | 2133 MHz |
Storage | |
Main Storage | 256 GB SSD PCIe |
Display | |
Type | 12" - IPS |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes (multi-touch) |
Resolution | 2880 x 1920 (QHD+) |
Widescreen | Yes |
Image Aspect Ratio | 3:2 |
Image Brightness | 400 cd/m² |
Features | Corning Gorilla glass |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes |
Resolution | 5 Megapixel (rear), 1 Megapixel (front) |
Camera Features | IR camera, rear camera with auto focus |
Sound | Speakers, two microphones |
Compliant Standards | Dolby Audio |
Input | |
Type | Digitizer, digital pen, detachable keyboard |
Keyboard Layout | UK |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 - M.2 Card |
Battery | |
Technology | 4-cell Lithium Ion |
Capacity | 41 Wh |
Run Time | Up to 8 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 20 V, 2.25 A |
Connections & Expansion | |
Interfaces Details | USB-C (charging) , USB 3.0 , USB 2.0 , Headphone/microphone combo jack , Keyboard |
Memory Card Reader | Yes (microSD) |
Miscellaneous | |
Colour | Black |
Features | Administrator password, power-on password, stand |
Included Accessories | Power adapter, keyboard, WACOM active capacitive pen |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 780 g |
Dimensions (WxDxH) / Weight Details | 29.3 cm x 21.6 cm x 1.46 cm / 1.1 kg - tablet with keyboard , 29.2 cm x 21 cm x 0.89 cm / 780 g - tablet |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - pick-up and return |
