Work or play - you decide. The Lenovo Miix 510 is the 2-in-1 PC that adapts to every moment. With its sleek design, amazing watchband hinges, and high performance - you can rely on the Miix 510 to power you through any situation.
Product Description | Lenovo IdeaPad Miix 510-12IKB - 12.2" - Intel Core i7 - 7500U - 8 GB RAM - 256 GB SSD - UK | Product Type | Tablet - with detachable keyboard | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i7 (7th Gen) - 7500U / 2.7 GHz, up to 3.5 GHz / 4 MB Cache | Memory | 8 GB LPDDR4 (provided memory is soldered) | Storage | 256 GB SSD | Display | 12.2" LED backlight touchscreen 1920 x 1200 / WUXGA | Graphics | Intel HD Graphics 620 | Input Device | Keyboard, touchpad | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1 | Battery | 2-cell | Colour | Platinum silver | Dimensions (WxDxH) - tablet | 30 cm x 20.5 cm x 0.99 cm | Weight | 880 g | Localisation | Language: English / region: United Kingdom | Manufacturer Warranty | Limited warranty - 1 year - pick-up and return |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i7 (7th Gen) 7500U / 2.7 GHz |
Max Turbo Speed | 3.5 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Features | Integrated memory controller |
Memory | |
RAM | 8 GB (provided memory is soldered) |
Technology | LPDDR4 SDRAM |
Speed | 2133 MHz / PC4-17000 |
Rated Speed | 2133 MHz |
Storage | |
Main Storage | 256 GB SSD PCIe |
Display | |
Type | 12.2" - IPS |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes (multi-touch) |
Resolution | 1920 x 1200 (WUXGA) |
Widescreen | Yes |
Image Aspect Ratio | 16:10 |
Image Brightness | 320 cd/m² |
Features | Corning Gorilla glass |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes |
Resolution | 5 Megapixel (rear), 2 Megapixel (front) |
Camera Features | Rear camera with auto focus |
Sound | Stereo speakers, two microphones |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Battery | |
Technology | 2-cell Lithium Ion |
Capacity | 39 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 20 V, 2.25 A |
Connections & Expansion | |
Interfaces Details | USB 3.0 (Always On) , USB-C , Headphone/microphone combo jack |
Memory Card Reader | Yes (microSD) |
Miscellaneous | |
Included Accessories | Power adapter, keyboard, active pen, pen holder |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 880 g |
Dimensions (WxDxH) / Weight Details | 30 cm x 20.5 cm x 0.99 cm / 880 g - tablet , 30 cm x 20.5 cm x 1.59 cm / 1.25 kg - tablet with keyboard |
Sustainability Information | |
TCO Certified | - |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - pick-up and return |
