The ThinkPad battery 44+ uses advanced Lithium-Ion technology to create an efficient power source for the X230 and X220 systems. These are compatible with the X220 and X230 systems and are ideal for use as a replacement or spare. The 6-cell batteries are rechargeable and allow you to stay unplugged for longer, lasting an average of 63 watt hours. However, they are not compatible with the ThinkPad External Battery Charger (40Y7625).
*Many factors cause battery life to differ. These include: power management, features, screen brightness, applications, battery conditioning and other customer preferences.
Product Description | Lenovo ThinkPad Battery 44+ - laptop battery - Li-Ion - 63 Wh | Device Type | Laptop battery | Weight | 345 g | Battery | Lithium Ion 6-cell - 63 Wh | Dimensions (WxDxH) | 20.88 cm x 5.51 cm x 2.28 cm | Manufacturer Warranty | 1-year warranty | Designed For | ThinkPad X220 4287, 4289, 4290, 4291, 4293; X220i 4286, 4287, 4290; X230 2306, 2320, 2324, 2325; X230i 2320 |
General | |
Battery | |
Technology | 6-cell Lithium Ion |
Voltage Provided | 11.1 V |
Capacity | 63 Wh |
Miscellaneous | |
Compliant Standards | UL, C-Tick, cUL, PSE Mark, ACA, KC |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 8 - 95% |
Dimensions & Weight | |
Width | 20.88 cm |
Depth | 5.51 cm |
Height | 2.28 cm |
Weight | 345 g |
Compatibility Information | |
Designed For | Lenovo ThinkPad X220 4287, 4289, 4290, 4291, 4293 , Lenovo ThinkPad X220i 4286, 4287, 4290 , Lenovo ThinkPad X230 2306, 2320, 2324, 2325 , Lenovo ThinkPad X230i 2320 |
