Recognizably different from the competitors, the Yoga 900 is unbelievably thin and elegant. From the 360° watchband hinge to the eye catching color options, this 2-in-1 will turn heads. Packed with the high processing power and customizable features, your Yoga 900 will be your constant companion.
Product Description | Lenovo Yoga 900-13ISK - 13.3" - Intel Core i5 - 6300U - 8 GB RAM - 256 GB SSD - UK | Product Type | Ultrabook - flip design | Operating System | Win 10 Pro | Processor | Intel Core i5 (6th Gen) - 6300U / 2.4 GHz, up to 3 GHz / 3 MB Cache | Memory | 8 GB LPDDR3 (provided memory is soldered) | Storage | 256 GB SSD | Display | 13.3" LED backlight touchscreen 3200 x 1800 / QHD+ | Graphics | Intel HD Graphics 520 | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1 | Battery | 4-cell - up to 9 hours | Features | Ambient light sensor, G-sensor | Colour | Champagne gold | Dimensions (WxDxH) | 32.4 cm x 22.5 cm x 1.49 cm | Weight | 1.29 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ |
General | |
Operating System | Windows 10 Pro |
Processor / Chipset | |
CPU | Intel Core i5 (6th Gen) 6300U / 2.4 GHz |
Max Turbo Speed | 3 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Integrated memory controller |
Memory | |
RAM | 8 GB (provided memory is soldered) |
Technology | LPDDR3 SDRAM |
Speed | 1600 MHz / PC3L-12800 |
Rated Speed | 1600 MHz |
Storage | |
Main Storage | 256 GB SSD M.2 PCIe |
Display | |
Type | 13.3" - IPS |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes (10-point multi-touch) |
Resolution | 3200 x 1800 (QHD+) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 300 cd/m² |
Features | One Glass Solution |
Audio & Video | |
Graphics Processor | Intel HD Graphics 520 |
Camera | Yes - 720p |
Resolution | 1 Megapixel |
Sound | Stereo speakers, two microphones |
Compliant Standards | High Definition Audio, Dolby Audio Premium |
Audio Features | Output: JBL |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Multi-touch touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Wireless Controller | Intel Dual Band Wireless-AC 8260 - M.2 Card |
Battery | |
Technology | 4-cell lithium polymer |
Capacity | 66 Wh |
Run Time | Up to 9 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt, 20 V, 3.25 A |
Connections & Expansion | |
Interfaces Details | 2 x USB 3.0 , USB 2.0 , Headphone/microphone combo jack , USB-C |
Memory Card Reader | 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card) |
Miscellaneous | |
Case Material | Aluminum, magnesium-aluminum alloy |
Integrated Options | Ambient light sensor, G-sensor |
Features | Administrator password, hard drive password, power-on password, digital compass, 1 USB 2.0 (DC-In combo), 1 USB 3.0 with Video-out, Pseudo Gyro |
Included Accessories | Power adapter |
Compliant Standards | RoHS |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.29 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
