The ThinkPad Battery ThinkPad Battery 55++ is a rechargeable system battery that can be used as replacement for aging system batteries or as a convenient spare battery.
Product Description | Lenovo ThinkPad Battery 55++ - laptop battery - Li-Ion - 94 Wh | Device Type | Laptop battery | Weight | 0.5 kg | Battery | Lithium Ion 9-cell - 94 Wh | Dimensions (WxDxH) | 21.8 cm x 7.9 cm x 2.1 cm | Manufacturer Warranty | 1-year warranty |
General | |
Battery | |
Technology | 9-cell Lithium Ion |
Capacity | 94 Wh |
Miscellaneous | |
Compliant Standards | UL, C-Tick, cUL, PSE Mark, ACA |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 8 - 95% |
Dimensions & Weight | |
Width | 21.8 cm |
Depth | 7.9 cm |
Height | 2.1 cm |
Weight | 0.5 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 29.5 cm |
Shipping Depth | 13.2 cm |
Shipping Height | 4.8 cm |
Shipping Weight | 0.63 kg |
